Ana içeriğe geç
Garmin StreetPilot c330 Screen Replacement
Neye ihtiyacın var
  1. Garmin StreetPilot c330 Screen Replacement, Outer Casing: adım 1, 3 resimden 1. Garmin StreetPilot c330 Screen Replacement, Outer Casing: adım 1, 3 resimden 2. Garmin StreetPilot c330 Screen Replacement, Outer Casing: adım 1, 3 resimden 3.
    • At the top of the outer frame, insert the plastic spudger into the groove in the center.
    • Lever the frame gently until it pops out of the case.
  2. Garmin StreetPilot c330 Screen Replacement: adım 2, 3 resimden 1. Garmin StreetPilot c330 Screen Replacement: adım 2, 3 resimden 2. Garmin StreetPilot c330 Screen Replacement: adım 2, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove the four screws around the screen.
  3. Garmin StreetPilot c330 Screen Replacement: adım 3, 2 resimden 1. Garmin StreetPilot c330 Screen Replacement: adım 3, 2 resimden 2.
    • Gently pull from both ends of the casing to separate the front and back panels.
    • Do not force the pieces apart wider than the length of the connecting wires, or you will damage the wiring.
  4. Garmin StreetPilot c330 Screen Replacement: adım 4, 3 resimden 1. Garmin StreetPilot c330 Screen Replacement: adım 4, 3 resimden 2. Garmin StreetPilot c330 Screen Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Gently unplug the white cable connector using either your fingers or tweezers.
  5. Garmin StreetPilot c330 Screen Replacement: adım 5, 1 resimden 1.
    • Carefully expose both halves of the device.
    • Be sure not to pull the two halves apart further than the black wire can reach.
  6. Garmin StreetPilot c330 Screen Replacement, Screen: adım 6, 3 resimden 1. Garmin StreetPilot c330 Screen Replacement, Screen: adım 6, 3 resimden 2. Garmin StreetPilot c330 Screen Replacement, Screen: adım 6, 3 resimden 3.
    • Remove the three screws holding the motherboard in place.
  7. Garmin StreetPilot c330 Screen Replacement: adım 7, 1 resimden 1.
    • Use the spudger to lift up the motherboard.
  8. Garmin StreetPilot c330 Screen Replacement: adım 8, 3 resimden 1. Garmin StreetPilot c330 Screen Replacement: adım 8, 3 resimden 2. Garmin StreetPilot c330 Screen Replacement: adım 8, 3 resimden 3.
    Satın Al
    • To remove the ribbon cable, lift the black latch using the spudger tool.
    • Separate the connection using either your fingers, tweezers, or the spudger.
  9. Garmin StreetPilot c330 Screen Replacement: adım 9, 2 resimden 1. Garmin StreetPilot c330 Screen Replacement: adım 9, 2 resimden 2.
    • Slide the spudger under the two flexible tabs located on the right and left sides of the bottom of the screen.
    • Rotate the spudger outward until the tabs are no longer holding the screen.
    • When reassembling, slide the bottom of the screen under the two permanent tabs.
    • Push the screen out from the front.
  10. Garmin StreetPilot c330 Screen Replacement: adım 10, 1 resimden 1.
    • Separate the screen from the front cover.
Sonuç
Adrian Leon
173 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 22-1, Maness Fall 2010 Cal Poly, Team 22-1, Maness Fall 2010 üyesi
CPSU-MANESS-F10S22G1
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 1,559
