Giriş
Replacing the buttons of the Garmin Vívoactive 4 (M/N: 03618) is a difficult process and requires multiple steps and tools.
If the buttons on your Garmin Vívoactive 4 seem unresponsive and don't operate correctly, it is recommended that you replace the entire housing unit as the buttons will come attached to replacement housing units.
Nonetheless, this guide will take you through the steps required to replace the buttons on your Garmin Vívoactive 4 watch.
This guide requires the use of a heat gun and iOpener. See these articles, How to Use a Heat Gun to Soften Adhesive and iOpener Instructions for instructions and safety information.
Neye ihtiyacın var
Wedge your fingernail or the tip of a spudger underneath the watch band's small metal pin.
Push on the pin to release the strap from it's hinge.
Pull the strap away from the watch to disconnect it.
Use a heatgun to loosen the adhesive beneath the screen, it should take a 5-10 minutes for adhesive to loosen.
Use the pointed tip of a spudger to carefully push on each side of the battery connector to disconnect the battery from the motherboard.
Wedge a spudger or your iFixit Jimmy in between the button's snap ring and the watch housing.
Carefully pry the snap ring off the button.
Remove the button and components from the watch housing.
