Ana içeriğe geç
Garmin Vivoactive Battery Replacement
Neye ihtiyacın var
  1. Garmin Vivoactive Battery Replacement, Wristband: adım 1, 1 resimden 1.
    • Hold the the metal screwdriver, with a T5 Torx bit, in your dominant hand.
    • Hold the rubber screwdriver, with a Hex T6 Torx bit, in your other hand.
    • While holding the rubber screwdriver in place, simultaneously unscrew the pin (counterclockwise) with the metal screwdriver in your dominant hand.
    FixBot'a Sor
    Yorum Ekle
  2. Garmin Vivoactive Battery Replacement: adım 2, 2 resimden 1. Garmin Vivoactive Battery Replacement: adım 2, 2 resimden 2.
    • Once the 1mm screw is removed, reinsert the metal screwdriver in that same hole.
    • Gently push the strap's pin out. It will begin to protrude from the other end.
    • Use your fingers to grab the exposed pin and slide it free. The strap should now be disconnected from the device.
    FixBot'a Sor
    Yorum Ekle
  3. Garmin Vivoactive Battery Replacement, Display Unit: adım 3, 1 resimden 1.
    • Place a heated iOpener over the display to loosen the adhesive.
    • After about a minute, the iOpener may be removed.
    • For more in depth instructions on using the iOpener, refer to the iOpener guide.
    FixBot'a Sor
    Yorum Ekle
  4. Garmin Vivoactive Battery Replacement: adım 4, 2 resimden 1. Garmin Vivoactive Battery Replacement: adım 4, 2 resimden 2.
    • Place the blue plastic opening tool in-between the screen and plastic casing of the watch and slowly pry up one side of the screen.
    FixBot'a Sor
    Yorum Ekle
  5. Garmin Vivoactive Battery Replacement: adım 5, 1 resimden 1.
    • Once the first side has come free, wedge the blue pick in between the screen and watch unit on that side.
    • Complete one pass around the perimeter of the screen to break the adhesive bond on all four sides.
    • Insert it a minimal distance to avoid damaging internal components.
    FixBot'a Sor
    Yorum Ekle
  6. Garmin Vivoactive Battery Replacement: adım 6, 1 resimden 1.
    • Use the blue plastic opening tool to pry up the side of the glass. Raise it to a point where your fingernail can fit in the gap.
    • Do the same on the opposite side of the device until you have a good grip of the screen.
    FixBot'a Sor
    Yorum Ekle
  7. Garmin Vivoactive Battery Replacement: adım 7, 1 resimden 1.
    • Obtain a careful grip of the screen from two of its sides.
    • Slowly lift the screen off of the case. Separate it just enough so as not to damage the connection to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  8. Garmin Vivoactive Battery Replacement: adım 8, 1 resimden 1.
    • Detach the orange tab that connects the screen to the motherboard with a gentle uplift using a plastic opening tool.
    • Upon completing this step, the screen should be free from the rest of the device.
    FixBot'a Sor
    Yorum Ekle
  9. Garmin Vivoactive Battery Replacement, Battery: adım 9, 2 resimden 1. Garmin Vivoactive Battery Replacement, Battery: adım 9, 2 resimden 2.
    • Follow previous guides until you've exposed the battery as shown.
    • Begin by removing the battery connector tab.
    • Be sure not to use a metal implement or your fingers to remove this tab. Doing so may cause personal harm or damage to the electrical components.
    FixBot'a Sor
    Yorum Ekle
  10. Garmin Vivoactive Battery Replacement: adım 10, 2 resimden 1. Garmin Vivoactive Battery Replacement: adım 10, 2 resimden 2.
    • Use a plastic opening pick to gently pry out the battery as shown.
    • The battery is Lithium Polymer, follow safe handling procedures and DO NOT deform it upon removal.
    FixBot'a Sor
    Yorum Ekle
  11. Garmin Vivoactive Battery Replacement: adım 11, 3 resimden 1. Garmin Vivoactive Battery Replacement: adım 11, 3 resimden 2. Garmin Vivoactive Battery Replacement: adım 11, 3 resimden 3.
    • With the battery loose from the case, rotate it to expose the attached tab
    • Gently pry up the attached tab with a fingernail.
    • Keep the vibrator, circled in red, as you may need to solder it to the new battery upon re-installation later.
    FixBot'a Sor
    Yorum Ekle
Sonuç
17 farklı kişi bu kılavuzu tamamladı.
Michael Clark
679 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 1-21, Maness Fall 2015 Cal Poly, Team 1-21, Maness Fall 2015 üyesi
CPSU-MANESS-F15S1G21
4 Üyeler
17 adet Kılavuz yazıldı
29Kılavuz Yorumları
But battery buy where?
sanborn - Yanıt Paylaş
where to buy battery?
Whitney Oliver - Yanıt Paylaş
I have the Same question... where can i buy the replacement?
Roli - Yanıt Paylaş
I've tried everywhere to find a battery for my vivoactive, with no luck. Where should I look to find a battery? HELP!
David - Yanıt Paylaş
Battery is a 3.7 V, 150 mAh Li-Polymer type.
Gary K - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 64
Son 30 gün: 279
Her zaman: 115,740
