Giriş
If the Vivoactive's display unit is cracked or still unresponsive after trying other solutions in our troubleshooting guide, this guide details how to replace the screen of the Vivoactive. This is a simple procedure that will leave your device looking new and functional again.
Note: Replacing the screen will damage the waterproof adhesive.
Neye ihtiyacın var
Hold the the metal screwdriver, with a T5 Torx bit, in your dominant hand.
Hold the rubber screwdriver, with a Hex T6 Torx bit, in your other hand.
While holding the rubber screwdriver in place, simultaneously unscrew the pin (counterclockwise) with the metal screwdriver in your dominant hand.
Place a heated iOpener over the display to loosen the adhesive.
After about a minute, the iOpener may be removed.
16 farklı kişi bu kılavuzu tamamladı.
39 Yorum
Does anyone knows where can I buy a vivoactive display?
Did anyone ever find a location where you can order a replacement screen?
Dylan
I've called Garmin support service but they said that displays units are not for sale from their side, only entire watch can be sold. I find it quite strange for not saying stupid because it's normal that using a watch displays can have a problem or that can be broken and easily fixed by replace them.
Being that said, if someone finds an alternative please share it, thanks
