Giriş
The continual use of the Vivoactive power button and action key may lead to dysfunctional buttons. This problem can be solved with the replacement of the buttons themselves to ensure all components are working correctly.
Neye ihtiyacın var
Hold the the metal screwdriver, with a T5 Torx bit, in your dominant hand.
Hold the rubber screwdriver, with a Hex T6 Torx bit, in your other hand.
While holding the rubber screwdriver in place, simultaneously unscrew the pin (counterclockwise) with the metal screwdriver in your dominant hand.
Place a heated iOpener over the display to loosen the adhesive.
After about a minute, the iOpener may be removed.
Follow previous guides until you've exposed the battery as shown.
Begin by removing the battery connector tab.
