Ana içeriğe geç
Garmin eTrex Vista H LCD screen Replacement
Neye ihtiyacın var
  1. Garmin eTrex Vista H LCD screen Replacement, Removing Battery: adım 1, 1 resimden 1.
    • Flip the device to the backside, and locate the metal tab at the center of the back cover.
  2. Garmin eTrex Vista H LCD screen Replacement: adım 2, 1 resimden 1.
    • Lift the metal tab up, and rotate it counterclockwise. This will unlock the back case cover.
  3. Garmin eTrex Vista H LCD screen Replacement: adım 3, 2 resimden 1. Garmin eTrex Vista H LCD screen Replacement: adım 3, 2 resimden 2.
    • Lift the battery plate off to either insert or remove 2 AA batteries.
  4. Garmin eTrex Vista H LCD screen Replacement, Disassembling the Garmin eTrex Vista-H Outer Case: adım 4, 2 resimden 1. Garmin eTrex Vista H LCD screen Replacement, Disassembling the Garmin eTrex Vista-H Outer Case: adım 4, 2 resimden 2.
    • With the wedge side of a spudger (or a small, flat head screwdriver), remove the black rubber case support from the device body.
  5. Garmin eTrex Vista H LCD screen Replacement: adım 5, 3 resimden 1. Garmin eTrex Vista H LCD screen Replacement: adım 5, 3 resimden 2. Garmin eTrex Vista H LCD screen Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    • With the pick side of a spudger (or tweezers), peel the sticky tape from the device.
  6. Garmin eTrex Vista H LCD screen Replacement: adım 6, 1 resimden 1.
    • Split the front and rear panels by inserting a small pointed tool (such as a pen point or a screwdriver tip SL1.5) in the 5 plastic tabs along the sides of the device.
    • Do not remove the back panels quickly. If too much force is applied, there is a wire connection that will break.
    • CAUTION! Be careful not to force the tabs inward. This will result in broken tabs.
  7. Garmin eTrex Vista H LCD screen Replacement: adım 7, 2 resimden 1. Garmin eTrex Vista H LCD screen Replacement: adım 7, 2 resimden 2.
    • With tweezers (or your fingernails), carefully disconnect the wires between the PC input and the motherboard.
  8. Garmin eTrex Vista H LCD screen Replacement, Disassembling Garmin eTrex Vista H Motherboard: adım 8, 1 resimden 1.
    • The motherboard should look like this. If it is dirty, gently use a small paintbrush to clean it of dust.
  9. Garmin eTrex Vista H LCD screen Replacement: adım 9, 1 resimden 1.
    • There are no screws holding the motherboard in place.
    • Carefully lift the motherboard from the case.
  10. Garmin eTrex Vista H LCD screen Replacement: adım 10, 2 resimden 1. Garmin eTrex Vista H LCD screen Replacement: adım 10, 2 resimden 2.
    • With the pointed end of a spudger (or the small end of a Philips #00 screwdriver), gently unhook the small black tabs by pressing into the interlocking hooks that are sunk into the white wire connector.
    • Gently pull the wire ribbon from the white connector.
    It is easy to pull the ribbon cable off, but reinserting the ribbon cable back into the wire connector is very challenging. Any tips?
    Robin Van Eyk - Yanıt
  11. Garmin eTrex Vista H LCD screen Replacement, LCD screen: adım 11, 3 resimden 1. Garmin eTrex Vista H LCD screen Replacement, LCD screen: adım 11, 3 resimden 2. Garmin eTrex Vista H LCD screen Replacement, LCD screen: adım 11, 3 resimden 3.
    • After removing the motherboard, locate the two #1 Philips screws.
    • Carefully remove both screws.
  12. Garmin eTrex Vista H LCD screen Replacement: adım 12, 2 resimden 1. Garmin eTrex Vista H LCD screen Replacement: adım 12, 2 resimden 2.
    • Gently remove the LCD screen from the case by lifting the area that held the two #1 Philips screws.
    • Do not remove the LSC screen by lifting the sides, only the area that held the two #1 Philips screws.
  13. Garmin eTrex Vista H LCD screen Replacement: adım 13, 1 resimden 1.
    • Insert the new LCD screen in the device.
    Hi, Sir, i need display units for garmin etrexH, and etrex10, please let me k now the unit cost and where i can buy...thanks
    shiva raj - Yanıt
    Hi, I was wondering where I could get one new screen for my garmin etrex legend HCx.
    Thank you very much,
    Jordi
    Arctictern - Yanıt
    Hi there…Could you please help…Looking for a replacement LCD screen for a Garmin Venture Etrex? Kind regards….
    leon.visagie75@gmail.com
    Leon Visagie - Yanıt
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Lauren Noyes
248 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-30, Regan Fall 2010 Cal Poly, Team 21-30, Regan Fall 2010 üyesi
CPSU-REGAN-F10S21G30
3 Üyeler
5 adet Kılavuz yazıldı
1Rehber Yorum
where can I find the LCD test
carlos gomes - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 26
Her zaman: 12,139
