Ana içeriğe geç
Garmin eTrex Vista H Replacing Antenna Replacement
Neye ihtiyacın var
  1. Garmin eTrex Vista H Replacing Antenna Replacement, Removing Battery: adım 1, 1 resimden 1.
    • Flip the device to the backside, and locate the metal tab at the center of the back cover.
  2. Garmin eTrex Vista H Replacing Antenna Replacement: adım 2, 1 resimden 1.
    • Lift the metal tab up, and rotate it counterclockwise. This will unlock the back case cover.
  3. Garmin eTrex Vista H Replacing Antenna Replacement: adım 3, 2 resimden 1. Garmin eTrex Vista H Replacing Antenna Replacement: adım 3, 2 resimden 2.
    • Lift the battery plate off to either insert or remove 2 AA batteries.
  4. Garmin eTrex Vista H Replacing Antenna Replacement, Disassembling the Garmin eTrex Vista-H Outer Case: adım 4, 2 resimden 1. Garmin eTrex Vista H Replacing Antenna Replacement, Disassembling the Garmin eTrex Vista-H Outer Case: adım 4, 2 resimden 2.
    • With the wedge side of a spudger (or a small, flat head screwdriver), remove the black rubber case support from the device body.
  5. Garmin eTrex Vista H Replacing Antenna Replacement: adım 5, 3 resimden 1. Garmin eTrex Vista H Replacing Antenna Replacement: adım 5, 3 resimden 2. Garmin eTrex Vista H Replacing Antenna Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • With the pick side of a spudger (or tweezers), peel the sticky tape from the device.
  6. Garmin eTrex Vista H Replacing Antenna Replacement: adım 6, 1 resimden 1.
    • Split the front and rear panels by inserting a small pointed tool (such as a pen point or a screwdriver tip SL1.5) in the 5 plastic tabs along the sides of the device.
    • Do not remove the back panels quickly. If too much force is applied, there is a wire connection that will break.
    • CAUTION! Be careful not to force the tabs inward. This will result in broken tabs.
  7. Garmin eTrex Vista H Replacing Antenna Replacement: adım 7, 2 resimden 1. Garmin eTrex Vista H Replacing Antenna Replacement: adım 7, 2 resimden 2.
    • With tweezers (or your fingernails), carefully disconnect the wires between the PC input and the motherboard.
  8. Garmin eTrex Vista H Replacing Antenna Replacement, Disassembling Garmin eTrex Vista H Motherboard: adım 8, 1 resimden 1.
    • The motherboard should look like this. If it is dirty, gently use a small paintbrush to clean it of dust.
  9. Garmin eTrex Vista H Replacing Antenna Replacement: adım 9, 1 resimden 1.
    • There are no screws holding the motherboard in place.
    • Carefully lift the motherboard from the case.
  10. Garmin eTrex Vista H Replacing Antenna Replacement: adım 10, 2 resimden 1. Garmin eTrex Vista H Replacing Antenna Replacement: adım 10, 2 resimden 2.
    • With the pointed end of a spudger (or the small end of a Philips #00 screwdriver), gently unhook the small black tabs by pressing into the interlocking hooks that are sunk into the white wire connector.
    • Gently pull the wire ribbon from the white connector.
  11. Garmin eTrex Vista H Replacing Antenna Replacement, Replacing Antenna: adım 11, 1 resimden 1.
    • Locate antenna on the back of the motherboard.
    • In order to replace the antennaa you have to purchase a new motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Taylor Hershey
12 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 21-30, Regan Fall 2010 Cal Poly, Team 21-30, Regan Fall 2010 üyesi
CPSU-REGAN-F10S21G30
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 4,578
