Ana içeriğe geç
Garmin inReach Explorer Plus LCD Screen Replacement
Neye ihtiyacın var
  1. Garmin inReach Explorer Plus LCD Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Using the TR6 Torx Security screwdriver, remove six 10 mm screws from the back cover of the device.
  2. Garmin inReach Explorer Plus LCD Screen Replacement: adım 2, 1 resimden 1.
    • Remove the back cover.
  3. Garmin inReach Explorer Plus LCD Screen Replacement: adım 3, 2 resimden 1. Garmin inReach Explorer Plus LCD Screen Replacement: adım 3, 2 resimden 2.
    • Gently grasp the battery wire and disconnect it from the device.
    • Remove the battery from the device.
  4. Garmin inReach Explorer Plus LCD Screen Replacement, Motherboard: adım 4, 2 resimden 1. Garmin inReach Explorer Plus LCD Screen Replacement, Motherboard: adım 4, 2 resimden 2.
    • Using the T5 Torx screwdriver, remove the six 6 mm screws from the motherboard.
  5. Garmin inReach Explorer Plus LCD Screen Replacement: adım 5, 2 resimden 1. Garmin inReach Explorer Plus LCD Screen Replacement: adım 5, 2 resimden 2.
    • Disconnect the LCD screen from the motherboard by lifting on the flap with the nylon spudger.
    • The metal spudger should only be used for serious prying power. If used incorrectly, the metal spudger may damage the components of a device.
  6. Garmin inReach Explorer Plus LCD Screen Replacement: adım 6, 2 resimden 1. Garmin inReach Explorer Plus LCD Screen Replacement: adım 6, 2 resimden 2.
    • Disconnect the antenna from the motherboard by lifting the wire with a nylon spudger.
  7. Garmin inReach Explorer Plus LCD Screen Replacement: adım 7, 3 resimden 1. Garmin inReach Explorer Plus LCD Screen Replacement: adım 7, 3 resimden 2. Garmin inReach Explorer Plus LCD Screen Replacement: adım 7, 3 resimden 3.
    • Gently lift the motherboard up and out of the device.
  8. Garmin inReach Explorer Plus LCD Screen Replacement, LCD Screen: adım 8, 2 resimden 1. Garmin inReach Explorer Plus LCD Screen Replacement, LCD Screen: adım 8, 2 resimden 2.
    • Using the T5 Torx screwdriver, remove the two 6 mm screws from the LCD screen.
  9. Garmin inReach Explorer Plus LCD Screen Replacement: adım 9, 3 resimden 1. Garmin inReach Explorer Plus LCD Screen Replacement: adım 9, 3 resimden 2. Garmin inReach Explorer Plus LCD Screen Replacement: adım 9, 3 resimden 3.
    • Use a nylon spudger to separate the LCD screen from the main body and remove the LCD screen.
Sonuç
Sean Kelley
387 İtibar
4 adet Kılavuz yazıldı
Ekip
Clemson, Team 5-4, Hunter Fall 2021 Clemson, Team 5-4, Hunter Fall 2021 üyesi
CLEM-HUNTER-F21S5G4
4 Üyeler
5 adet Kılavuz yazıldı
3Kılavuz Yorumları
Where do I purchase the replacement LCD screen?
Tyler Lawrence - Yanıt
Ditto - where can we get a screen??
Ben Wallbank - Yanıt
Yes where can LCD SCREEN BE BOUGHT
Roy Shields - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 10
Son 30 gün: 24
Her zaman: 1,440
