Ana içeriğe geç
Garmin nüvi 3590 LMT Light Sensor Replacement
Neye ihtiyacın var
  1. Garmin nüvi 3590 LMT Light Sensor Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the device off by pressing and holding the power button on the top left of the device.
  2. Garmin nüvi 3590 LMT Light Sensor Replacement: adım 2, 1 resimden 1.
    • Use the plastic opening tool to separate the tabs on the black back cover of the device by leveraging the tool against the frame around the perimeter of the device.
  3. Garmin nüvi 3590 LMT Light Sensor Replacement: adım 3, 1 resimden 1.
    • Once all of the tabs are popped out, take the back cover off.
    • The back cover is a separate piece from the device.
  4. Garmin nüvi 3590 LMT Light Sensor Replacement: adım 4, 2 resimden 1. Garmin nüvi 3590 LMT Light Sensor Replacement: adım 4, 2 resimden 2.
    • Using the plastic spudger, carefully remove the white tab connected to the battery from the device by pulling the tab in the opposite direction from which it is connected.
  5. Garmin nüvi 3590 LMT Light Sensor Replacement: adım 5, 3 resimden 1. Garmin nüvi 3590 LMT Light Sensor Replacement: adım 5, 3 resimden 2. Garmin nüvi 3590 LMT Light Sensor Replacement: adım 5, 3 resimden 3.
    • Use the plastic spudger to lift the battery up and away from the device.
    • Do not puncture or bend the battery. Serious health complications could occur.
  6. Garmin nüvi 3590 LMT Light Sensor Replacement, Light Sensor: adım 6, 2 resimden 1. Garmin nüvi 3590 LMT Light Sensor Replacement, Light Sensor: adım 6, 2 resimden 2.
    • Using the T5 bit, unscrew the four 5.7mm screws in the four corners of the device.
  7. Garmin nüvi 3590 LMT Light Sensor Replacement: adım 7, 3 resimden 1. Garmin nüvi 3590 LMT Light Sensor Replacement: adım 7, 3 resimden 2. Garmin nüvi 3590 LMT Light Sensor Replacement: adım 7, 3 resimden 3.
    • Leverage the plastic opening tool to pop the tabs between the black screen and the metal frame around the perimeter of the device.
    • Do not forcibly separate the two pieces after the tabs have been popped as there are connections between the two pieces that could be torn.
  8. Garmin nüvi 3590 LMT Light Sensor Replacement: adım 8, 2 resimden 1. Garmin nüvi 3590 LMT Light Sensor Replacement: adım 8, 2 resimden 2.
    • Using your fingers, pull the red and black wire from the back of the screen.
  9. Garmin nüvi 3590 LMT Light Sensor Replacement: adım 9, 2 resimden 1. Garmin nüvi 3590 LMT Light Sensor Replacement: adım 9, 2 resimden 2.
    • Locate the red and black wire connected to the circuit board with the round, black, rubbery disc that was connected to the other half of the device (that disc is the light sensor). Gently pull the wire up from the circuit board.
Sonuç
Bir başkası bu kılavuzu tamamladı.
David
424 İtibar
3 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 4-1, Panko Spring 2015 Colorado Springs, Team 4-1, Panko Spring 2015 üyesi
UCCS-PANKO-S15S4G1
2 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 396
