Ana içeriğe geç
Garmin nuviCam LMTHD Battery Replacement
Neye ihtiyacın var
  1. Garmin nuviCam LMTHD Battery Replacement, Screen: adım 1, 2 resimden 1. Garmin nuviCam LMTHD Battery Replacement, Screen: adım 1, 2 resimden 2.
    • Remove the four 6.9 mm black screws using the T6 screw bit.
  2. Garmin nuviCam LMTHD Battery Replacement: adım 2, 2 resimden 1. Garmin nuviCam LMTHD Battery Replacement: adım 2, 2 resimden 2.
    • Pry the device open using a plastic opening tool.
    • We suggest starting from the dash camera side for easier opening
    • You may have to use a little force, the screen is hard to remove.
  3. Garmin nuviCam LMTHD Battery Replacement: adım 3, 1 resimden 1.
    • Disconnect the black and red wire from the screen.
  4. Garmin nuviCam LMTHD Battery Replacement: adım 4, 2 resimden 1. Garmin nuviCam LMTHD Battery Replacement: adım 4, 2 resimden 2.
    • Disconnect the orange strip by flipping up the connector with a plastic opening tool and sliding the cable out.
  5. Garmin nuviCam LMTHD Battery Replacement, Battery: adım 5, 1 resimden 1.
    • Locate the white box in your device which is the battery.
  6. Garmin nuviCam LMTHD Battery Replacement: adım 6, 1 resimden 1.
    • Disconnect battery from device pulling the green, red, and black wires from motherboard.
  7. Garmin nuviCam LMTHD Battery Replacement: adım 7, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Disconnect orange cable strip laying across battery by sliding it out of connector .
    • It may be at your benefit to use tweezers. It will be easier to reconnect the orange ribbon later with this tool.
  8. Garmin nuviCam LMTHD Battery Replacement: adım 8, 1 resimden 1.
    • Pry battery out of device.
    • Battery is glued into device, so it may be difficult to remove.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
4Kılavuz Yorumları
Where did you buy the battery? What is the voltage/current?
John Justin - Yanıt
It is nice to see how to remove the battery, but would like to have one handy before I start. Where can I buy one and what are the specifications?
Gary - Yanıt
I believe Garmin Part No. 361-00066-00 is correct (also used in the Nuvi 27xx series). It is available on AMazon and eBay.
guy.adamson - Yanıt
Anyone else having issues getting it to charge?
Just shows a red battery with a question mark.
Zach - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 51
Her zaman: 5,479
