Ana içeriğe geç
Garmin nuviCam LMTHD Motherboard Replacement
Neye ihtiyacın var
  1. Garmin nuviCam LMTHD Motherboard Replacement, Screen: adım 1, 2 resimden 1. Garmin nuviCam LMTHD Motherboard Replacement, Screen: adım 1, 2 resimden 2.
    • Remove the four 6.9 mm black screws using the T6 screw bit.
  2. Garmin nuviCam LMTHD Motherboard Replacement: adım 2, 2 resimden 1. Garmin nuviCam LMTHD Motherboard Replacement: adım 2, 2 resimden 2.
    • Pry the device open using a plastic opening tool.
    • We suggest starting from the dash camera side for easier opening
    • You may have to use a little force, the screen is hard to remove.
  3. Garmin nuviCam LMTHD Motherboard Replacement: adım 3, 1 resimden 1.
    • Disconnect the black and red wire from the screen.
  4. Garmin nuviCam LMTHD Motherboard Replacement: adım 4, 2 resimden 1. Garmin nuviCam LMTHD Motherboard Replacement: adım 4, 2 resimden 2.
    • Disconnect the orange strip by flipping up the connector with a plastic opening tool and sliding the cable out.
  5. Garmin nuviCam LMTHD Motherboard Replacement, Motherboard: adım 5, 1 resimden 1.
    • Disconnect battery wire from motherboard.
  6. Garmin nuviCam LMTHD Motherboard Replacement: adım 6, 1 resimden 1.
    • Disconnect yellow ribbon cable from motherboard.
  7. Garmin nuviCam LMTHD Motherboard Replacement: adım 7, 1 resimden 1.
    • Pull off black and red wire from screen.
  8. Garmin nuviCam LMTHD Motherboard Replacement: adım 8, 1 resimden 1.
    • Disconnect the orange cable strip connected to the screen using a plastic opening tool, lift white teeth up and slide strip out.
  9. Garmin nuviCam LMTHD Motherboard Replacement: adım 9, 1 resimden 1.
    • Remove silver plate from motherboard.
  10. Garmin nuviCam LMTHD Motherboard Replacement: adım 10, 2 resimden 1. Garmin nuviCam LMTHD Motherboard Replacement: adım 10, 2 resimden 2.
    • Remove all six 5.74mm screws from motherboard using the T4 screw bit.
  11. Garmin nuviCam LMTHD Motherboard Replacement: adım 11, 2 resimden 1. Garmin nuviCam LMTHD Motherboard Replacement: adım 11, 2 resimden 2.
    • Lift motherboard out of device using plastic opening tools.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Where to buy the replacement mother board? I couldn't find one.
BTW: Nicely done guide.
pitt83 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 724
