Ana içeriğe geç
Garmin nuviCam LMTHD Speaker Replacement
Neye ihtiyacın var
  1. Garmin nuviCam LMTHD Speaker Replacement, Screen: adım 1, 2 resimden 1. Garmin nuviCam LMTHD Speaker Replacement, Screen: adım 1, 2 resimden 2.
    • Remove the four 6.9 mm black screws using the T6 screw bit.
  2. Garmin nuviCam LMTHD Speaker Replacement: adım 2, 2 resimden 1. Garmin nuviCam LMTHD Speaker Replacement: adım 2, 2 resimden 2.
    • Pry the device open using a plastic opening tool.
    • We suggest starting from the dash camera side for easier opening
    • You may have to use a little force, the screen is hard to remove.
  3. Garmin nuviCam LMTHD Speaker Replacement: adım 3, 1 resimden 1.
    • Disconnect the black and red wire from the screen.
  4. Garmin nuviCam LMTHD Speaker Replacement: adım 4, 2 resimden 1. Garmin nuviCam LMTHD Speaker Replacement: adım 4, 2 resimden 2.
    • Disconnect the orange strip by flipping up the connector with a plastic opening tool and sliding the cable out.
  5. Garmin nuviCam LMTHD Speaker Replacement, Speaker: adım 5, 2 resimden 1. Garmin nuviCam LMTHD Speaker Replacement, Speaker: adım 5, 2 resimden 2.
    • Locate the speaker in the corner opposite of the dashcam.
    • Pry speaker out of device using a plastic opening tool.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 465
