Ana içeriğe geç
Garmin vívofit 2 Batteries Replacement
Neye ihtiyacın var
  1. Garmin vívofit 2 Batteries Replacement, Wristband: adım 1, 2 resimden 1. Garmin vívofit 2 Batteries Replacement, Wristband: adım 1, 2 resimden 2.
    • Carefully peel back the wristband so the bottom of the device is facing you. Then, pull out the device from one side (on the short edge) and take the device out of the wrist band.
  2. Garmin vívofit 2 Batteries Replacement, Batteries: adım 2, 1 resimden 1.
    • Remove the four 3.8mm Phillips #00 screws holding the device together.
  3. Garmin vívofit 2 Batteries Replacement: adım 3, 1 resimden 1.
    • With the screws removed from the device, take the cover off the top of the device, revealing the batteries inside.
  4. Garmin vívofit 2 Batteries Replacement: adım 4, 1 resimden 1.
    • With the cover removed, take out the two batteries currently in the device. Take note of which side of the battery is facing which way in the device. Battery removal can usually be accomplished with your fingers. If not, carefully use a nylon spudger to pull up one edge of the battery, allowing you to remove that battery.
Sonuç
Bir başkası bu kılavuzu tamamladı.
James Hickey
290 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G2, Harley Spring 2018 IUPUI, Team S1-G2, Harley Spring 2018 üyesi
IUPUI-HARLEY-S18S1G2
7 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 21
Her zaman: 3,556
