Carefully remove entire ceramic briquette casing from above the stainless steel burner.
Locate the six screws located on top of the ceramic briquette casing and unscrew them using your phillips head screwdriver.
Using your hands, gently unscrew washers from the back of the casing.
Separate the front and back metal casings surrounding the briquettes.
Take out old and used briquettes and dispose of them. (They will probably be black and tarnished)
Take 16 new ceramic briquettes out and carefully align them inside the casing.
3 farklı kişi bu kılavuzu tamamladı.
