Ana içeriğe geç
Gateway 3545GZ Fan Replacement
Neye ihtiyacın var
  1. Gateway 3545GZ Fan Replacement, Fan: adım 1, 2 resimden 1. Gateway 3545GZ Fan Replacement, Fan: adım 1, 2 resimden 2.
    • Unscrew 14mm screws with Phillips screwdriver.
    • Unscrew 3mm screws with the same Phillips screwdriver.
    • Screws that are circled in red are 3mm; the screw circled in blue is 14mm
    • Remove the protective cover.
  2. Gateway 3545GZ Fan Replacement: adım 2, 3 resimden 1. Gateway 3545GZ Fan Replacement: adım 2, 3 resimden 2. Gateway 3545GZ Fan Replacement: adım 2, 3 resimden 3.
    • Unscrew the four screws holding it in place with the same PH1 Phillips-Head screwdriver. They are numbered on the fan, 1,2,3,4.
    • The four screws are 12mm long, they also have a spring surrounding them.
    • Then carefully pull the cord connecting the fan to the notebook.
    • Insert your replacement fan, plug in its cord, screw it into place, and reattach the protective cover.
Sonuç
Nathan Parr
25 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 22
Her zaman: 273
