Ana içeriğe geç
Gateway 3545GZ Hard Drive Replacement
Neye ihtiyacın var
  1. Gateway 3545GZ Hard Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Flip the laptop so that the bottom is facing you. You will find in the lower left-hand corner a hole with a small screw; unscrew this with a PH1 Phillips-head screwdriver (Has a plus shape).
    • Screw Length: 3mm
  2. Gateway 3545GZ Hard Drive Replacement: adım 2, 1 resimden 1.
    • Lift up the plastic plate from the outer edge.
  3. Gateway 3545GZ Hard Drive Replacement: adım 3, 1 resimden 1.
    • Finally, slide the hard drive out of its dock; then just lift the hard drive out of the pocket.
Sonuç
Bryan Rickle
1 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 14
Son 30 gün: 15
Her zaman: 325
