Ana içeriğe geç
Gateway 600YG2 CD/DVD or Floppy drives Replacement
  1. Gateway 600YG2 CD/DVD or Floppy drives Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop over.
    • Slide the battery release tab to the right with your index finger to open the battery cover.
  2. Gateway 600YG2 CD/DVD or Floppy drives Replacement: adım 2, 1 resimden 1.
    • Remove the battery cover using the tab on the right side.
    • Use your index finger to help lift and remove the battery.
  3. Gateway 600YG2 CD/DVD or Floppy drives Replacement, CD/DVD or Floppy drives: adım 3, 1 resimden 1.
    • Slide the release and push the button to eject the drive.
    • Remove the drive.
    • When reinserting the drives, be sure to put them in the original slot to avoid interface conflicts.
Sonuç
Elizabeth Mazer
78 İtibar
10 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-10, Maness Fall 2010 Cal Poly, Team 20-10, Maness Fall 2010 üyesi
CPSU-MANESS-F10S20G10
3 Üyeler
22 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 1,654
