Ana içeriğe geç
Gateway 600YG2 LCD Replacement
Neye ihtiyacın var
  1. Gateway 600YG2 LCD Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop over.
    • Slide the battery release tab to the right with your index finger to open the battery cover.
  2. Gateway 600YG2 LCD Replacement: adım 2, 1 resimden 1.
    • Remove the battery cover using the tab on the right side.
    • Take the battery out with your index finger.
  3. Gateway 600YG2 LCD Replacement, Power Button Panel: adım 3, 1 resimden 1.
    • Insert the spudger between the "sysrq" and "ins" keys.
    • Gently pry free the power button panel above the keyboard, beginning from the right and moving to the left.
  4. Gateway 600YG2 LCD Replacement, LCD: adım 4, 1 resimden 1.
    • Remove the five screws with a Phillips #0 screwdriver.
    • The LCD hinge covers are held in place by four screws. One screw is for grounding the LCD.
    • Lift the hinge covers along the outer edges with the spudger until they are released.
  5. Gateway 600YG2 LCD Replacement: adım 5, 1 resimden 1.
    • Gently unplug the LCD from the system board.
  6. Gateway 600YG2 LCD Replacement: adım 6, 1 resimden 1.
    • Using the Phillips #0 screwdriver, remove six screws that hold the LCD to the hinge.
  7. Gateway 600YG2 LCD Replacement: adım 7, 1 resimden 1.
    • Check if any cables are still connected before pulling out the LCD.
    • Remove the cable by gently pulling it out while holding down the LCD.
Sonuç
Elizabeth Mazer
78 İtibar
10 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-10, Maness Fall 2010 Cal Poly, Team 20-10, Maness Fall 2010 üyesi
CPSU-MANESS-F10S20G10
3 Üyeler
22 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 1,872
