Ana içeriğe geç
Giriş
Removal of LCD display
Parçalar
Hiçbir parça belirtilmedi.
  1. Flip the laptop over. Slide the battery release tab to the right.
    • Flip the laptop over. Slide the battery release tab to the right.
  2. Lift the battery out.
    • Lift the battery out.
  3. Insert spudger between sysrq and ins keys.
    • Insert spudger between sysrq and ins keys.
    • Gently lift power button panel from the right to left.
  4. Dizüstü Bilgisayar Bataryaları
    An easy fix for a big power boost.
    Hemen Alışveriş Yapın
  5. Remove 5 screws.
    • Remove 5 screws.
    • 4 screws holding LCD hinge covers in place and 1 screw for LCD grounding.
    • Remove hinge covers.
  6. Gently unplug LCD from system board.
    • Gently unplug LCD from system board.
  7. Remove 6 screws holding LCD to hinge.
    • Remove 6 screws holding LCD to hinge.
  8. Pull LCD away from case.
    • Pull LCD away from case.
Sonuç
Elizabeth Mazer
78 İtibar
10 adet Kılavuz yazıldı
Takım
Cal Poly, Team 20-10, Maness Fall 2010 Cal Poly, Team 20-10, Maness Fall 2010 üyesi
CPSU-MANESS-F10S20G10
3 Üyeler
22 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 1,706
