Ana içeriğe geç
Gateway 600YG2 LCD Replacement
Neye ihtiyacın var
  1. Gateway 600YG2 LCD Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop over.
    • Slide the battery release tab to the right to open the battery cover.
    FixBot'a Sor
    Yorum Ekle
  2. Gateway 600YG2 LCD Replacement: adım 2, 1 resimden 1.
    • Remove the battery cover using the tab on the right side.
    • Lift and remove the battery.
    FixBot'a Sor
    Yorum Ekle
  3. Gateway 600YG2 LCD Replacement, Power Button Panel: adım 3, 1 resimden 1.
    • Insert the spudger between the "sysrq" and "ins" keys.
    • Gently pry free the power button panel above the keyboard, from the right and moving to the left.
    FixBot'a Sor
    Yorum Ekle
  4. Gateway 600YG2 LCD Replacement, LCD: adım 4, 1 resimden 1.
    • Remove the five screws with a Phillips #0 screwdriver.
    • The LCD hinge covers are held in place by four screws. One screw is for grounding the LCD.
    • Lift the hinge covers along the outer edges with the spudger until they are released.
    FixBot'a Sor
    Yorum Ekle
  5. Gateway 600YG2 LCD Replacement: adım 5, 1 resimden 1.
    • Gently unplug the LCD from the system board.
    FixBot'a Sor
    Yorum Ekle
  6. Gateway 600YG2 LCD Replacement: adım 6, 1 resimden 1.
    • Using the Phillips #0 screwdriver, remove six screws that hold the LCD to the hinge.
    FixBot'a Sor
    Yorum Ekle
  7. Gateway 600YG2 LCD Replacement: adım 7, 1 resimden 1.
    • Check if any cables are still connected before pulling out the LCD.
    • Remove the cable by gently pulling it out while holding down the LCD.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Elizabeth Mazer
78 İtibar
10 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-10, Maness Fall 2010 Cal Poly, Team 20-10, Maness Fall 2010 üyesi
CPSU-MANESS-F10S20G10
3 Üyeler
22 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 35
Her zaman: 2,361
