Ana içeriğe geç
Gateway 600YG2 Memory Replacement
Neye ihtiyacın var
  1. Gateway 600YG2 Memory Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop over.
    • Slide the battery release tab to the right with your index finger to open the battery cover.
  2. Gateway 600YG2 Memory Replacement: adım 2, 1 resimden 1.
    • Remove the battery cover using the tab on the right side.
    • Use your index finger to help lift and remove the battery.
  3. Gateway 600YG2 Memory Replacement, Memory: adım 3, 1 resimden 1.
    • Remove access cover by unscrewing captive screw.
  4. Gateway 600YG2 Memory Replacement: adım 4, 1 resimden 1.
    • Slide locking tabs outward
  5. Gateway 600YG2 Memory Replacement: adım 5, 1 resimden 1.
    • Slide memory module out
Sonuç
Elizabeth Mazer
78 İtibar
10 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-10, Maness Fall 2010 Cal Poly, Team 20-10, Maness Fall 2010 üyesi
CPSU-MANESS-F10S20G10
3 Üyeler
22 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,593
