Ana içeriğe geç
Gateway 600YG2 System Fan Replacement
Neye ihtiyacın var
  1. Gateway 600YG2 System Fan Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop over.
    • Slide the battery release tab to the right to open the battery cover.
    FixBot'a Sor
    Yorum Ekle
  2. Gateway 600YG2 System Fan Replacement: adım 2, 1 resimden 1.
    • Remove the battery cover using the tab on the right side.
    • Lift and remove the battery.
    FixBot'a Sor
    Yorum Ekle
  3. Gateway 600YG2 System Fan Replacement, Keyboard: adım 3, 1 resimden 1.
    • Remove the five screws holding the keyboard in place.
    FixBot'a Sor
    Yorum Ekle
  4. Gateway 600YG2 System Fan Replacement: adım 4, 2 resimden 1. Gateway 600YG2 System Fan Replacement: adım 4, 2 resimden 2.
    • Possible device damage: When lifting the keyboard out, do not lift the keyboard up. Only fold back along the space bar edge.
    • Possible device damage: Do not pull the black cable by the ribbon section. Only pull it from the connector itself.
    • Follow the black ribbon cable and gently pull straight up.
    FixBot'a Sor
    Yorum Ekle
  5. Gateway 600YG2 System Fan Replacement, System Fan: adım 5, 2 resimden 1. Gateway 600YG2 System Fan Replacement, System Fan: adım 5, 2 resimden 2.
    • Unscrew the four captive screws.
    • Unplug the fan from the system and pull it out. This should slide forward before coming free.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Elizabeth Mazer
78 İtibar
10 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-10, Maness Fall 2010 Cal Poly, Team 20-10, Maness Fall 2010 üyesi
CPSU-MANESS-F10S20G10
3 Üyeler
22 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 36
Her zaman: 2,684
