Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
Removal of the system fan. when following the keyboard instructions there is no need to unplug it only fold it back to gain access to the fan.
Parçalar
Hiçbir parça belirtilmedi.
  1. Flip the laptop over. Slide the battery release tab to the right.
    • Flip the laptop over. Slide the battery release tab to the right.
  2. Lift the battery out.
    • Lift the battery out.
  3. Nintendo Switch Kit'leri
    Oyuna geri dönmek için hızlı bir düzeltme
    Switch Kit'leri Satın Al
  4. Remove the 5 screws holding the keyboard in place.
    • Remove the 5 screws holding the keyboard in place.
  5. CAUTION: When lifting the keyboard out, do not lift keyboard up. Only fold back along the space bar edge. DO NOT PULL the black cable by the ribbon section; only pull it by the connector itself.
    • CAUTION: When lifting the keyboard out, do not lift keyboard up. Only fold back along the space bar edge.
    • DO NOT PULL the black cable by the ribbon section; only pull it by the connector itself.
    • Follow the black ribbon cable to the connector and gently pull straight up.
  6. Unscrew the 4 captive screws. Unplug fan from the system and pull it out. The fan unit should slide forward before coming free.
    • Unscrew the 4 captive screws.
    • Unplug fan from the system and pull it out. The fan unit should slide forward before coming free.
Sonuç
Elizabeth Mazer
78 İtibar
10 adet Kılavuz yazıldı
Takım
Cal Poly, Team 20-10, Maness Fall 2010 Cal Poly, Team 20-10, Maness Fall 2010 üyesi
CPSU-MANESS-F10S20G10
3 Üyeler
22 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 2,067
