Ana içeriğe geç
Gateway 600YGR RAM Replacement
Neye ihtiyacın var
  1. Gateway 600YGR RAM  Replacement, RAM: adım 1, 2 resimden 1. Gateway 600YGR RAM  Replacement, RAM: adım 1, 2 resimden 2.
    • Flip the computer over so that the bottom of your device is face up.
    FixBot'a Sor
    Yorum Ekle
  2. Gateway 600YGR RAM  Replacement: adım 2, 3 resimden 1. Gateway 600YGR RAM  Replacement: adım 2, 3 resimden 2. Gateway 600YGR RAM  Replacement: adım 2, 3 resimden 3.
    • Use a Philips head screwdriver and the PH1 bit to remove the indicated 5.35mm screw.
    • Remove the cover panel.
    FixBot'a Sor
    Yorum Ekle
  3. Gateway 600YGR RAM  Replacement: adım 3, 3 resimden 1. Gateway 600YGR RAM  Replacement: adım 3, 3 resimden 2. Gateway 600YGR RAM  Replacement: adım 3, 3 resimden 3.
    • Locate the indicated tabs on the edges of the top RAM board.
    • Pull the tabs outward and the RAM board will release.
    • Remove the RAM board.
    FixBot'a Sor
    Yorum Ekle
  4. Gateway 600YGR RAM  Replacement: adım 4, 2 resimden 1. Gateway 600YGR RAM  Replacement: adım 4, 2 resimden 2.
    • Locate the indicated tabs on the edges of the bottom RAM board.
    • Pull the tabs outward.
    FixBot'a Sor
    Yorum Ekle
  5. Gateway 600YGR RAM  Replacement: adım 5, 2 resimden 1. Gateway 600YGR RAM  Replacement: adım 5, 2 resimden 2.
    • You have now successfully removed the RAM boards.
    FixBot'a Sor
    Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 45
Her zaman: 450
