Giriş
Use this guide to replace a worn out battery for your Gateway GWTC116-2BL laptop. If your computer is shutting down randomly, this may mean you need a new battery. Overheating of your computer means your computer is working too hard. This guide will show you a simplified step-by-step break down to replace your battery. Before starting this replacement guide, be sure to be grounded before handling the battery.
Neye ihtiyacın var
Remove the ten 3.0 mm Phillips #00 screws from the back panel of the laptop.
2 farklı kişi bu kılavuzu tamamladı.
