Ana içeriğe geç
Gateway GWTC116-2BL Daughterboard Replacement
Neye ihtiyacın var
  1. Gateway GWTC116-2BL Daughterboard Replacement, Back Panel: adım 1, 1 resimden 1.
    • Ground yourself before disassembling and handling the computer.
    • Remove the ten 3.0 mm Phillips #00 screws from the back panel of the laptop.
  2. Gateway GWTC116-2BL Daughterboard Replacement: adım 2, 2 resimden 1. Gateway GWTC116-2BL Daughterboard Replacement: adım 2, 2 resimden 2.
    • Use the spudger to pry the back panel away from the body of the laptop.
  3. Gateway GWTC116-2BL Daughterboard Replacement, Battery: adım 3, 1 resimden 1.
    • Remove the five 3.0 mm Phillips #00 screws.
  4. Gateway GWTC116-2BL Daughterboard Replacement: adım 4, 2 resimden 1. Gateway GWTC116-2BL Daughterboard Replacement: adım 4, 2 resimden 2.
    • Using your fingers, flick open the battery connector bracket.
    • Remove the connector from bracket.
  5. Gateway GWTC116-2BL Daughterboard Replacement: adım 5, 1 resimden 1.
    • Pull up the battery to remove from the base.
  6. Gateway GWTC116-2BL Daughterboard Replacement, Daughterboard: adım 6, 2 resimden 1. Gateway GWTC116-2BL Daughterboard Replacement, Daughterboard: adım 6, 2 resimden 2.
    • Peel off the yellow piece of tape that is placed over the daughterboard.
  7. Gateway GWTC116-2BL Daughterboard Replacement: adım 7, 1 resimden 1.
    • Remove the three 3.0 mm Phillips #00 screws.
  8. Gateway GWTC116-2BL Daughterboard Replacement: adım 8, 2 resimden 1. Gateway GWTC116-2BL Daughterboard Replacement: adım 8, 2 resimden 2.
    • Flick open the bracket that connects the motherboard and daughterboard.
    • Remove the connector strip.
  9. Gateway GWTC116-2BL Daughterboard Replacement: adım 9, 1 resimden 1.
    • Remove the daughterboard from the base of the computer.
Sonuç
Kailey Sousa
513 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-2, Botvin Spring 2024 UMass Dartmouth, Team 6-2, Botvin Spring 2024 üyesi
UMASSD-BOTVIN-S24S6G2
3 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 24
Her zaman: 203
