Ana içeriğe geç
Gateway GWTC116-2BL Display Replacement
Neye ihtiyacın var
  1. Gateway GWTC116-2BL Display Replacement, Back Panel: adım 1, 1 resimden 1.
    • Ground yourself before disassembling and handling the computer.
    • Remove the ten 3.0 mm Phillips #00 screws from the back panel of the laptop.
  2. Gateway GWTC116-2BL Display Replacement: adım 2, 2 resimden 1. Gateway GWTC116-2BL Display Replacement: adım 2, 2 resimden 2.
    • Use the spudger to pry the back panel away from the body of the laptop.
  3. Gateway GWTC116-2BL Display Replacement, Battery: adım 3, 1 resimden 1.
    • Remove the five 3.0 mm Phillips #00 screws.
  4. Gateway GWTC116-2BL Display Replacement: adım 4, 2 resimden 1. Gateway GWTC116-2BL Display Replacement: adım 4, 2 resimden 2.
    • Using your fingers, flick open the battery connector bracket.
    • Remove the connector from bracket.
  5. Gateway GWTC116-2BL Display Replacement: adım 5, 1 resimden 1.
    • Pull up the battery to remove from the base.
  6. Gateway GWTC116-2BL Display Replacement, Motherboard: adım 6, 1 resimden 1.
    • Using your fingers, flick the cable connector bracket open.
    • Remove the cable from the connector.
  7. Gateway GWTC116-2BL Display Replacement: adım 7, 2 resimden 1. Gateway GWTC116-2BL Display Replacement: adım 7, 2 resimden 2.
    • Using your fingers, disconnect the black and white connector brackets underneath the gray cable.
  8. Gateway GWTC116-2BL Display Replacement: adım 8, 2 resimden 1. Gateway GWTC116-2BL Display Replacement: adım 8, 2 resimden 2.
    • Remove the four 3.0 mm Phillips #00 screws located on the motherboard casing.
  9. Gateway GWTC116-2BL Display Replacement: adım 9, 3 resimden 1. Gateway GWTC116-2BL Display Replacement: adım 9, 3 resimden 2. Gateway GWTC116-2BL Display Replacement: adım 9, 3 resimden 3.
    • Peel the yellow tape off of the casing.
    • Lift the casing off of the motherboard.
  10. Gateway GWTC116-2BL Display Replacement: adım 10, 2 resimden 1. Gateway GWTC116-2BL Display Replacement: adım 10, 2 resimden 2.
    • Peel off the yellow tape.
    • Remove four 3.0 mm Phillips #00 screws.
  11. Gateway GWTC116-2BL Display Replacement: adım 11, 2 resimden 1. Gateway GWTC116-2BL Display Replacement: adım 11, 2 resimden 2.
    • Peel off the black piece of tape covering the display cable.
  12. Gateway GWTC116-2BL Display Replacement: adım 12, 2 resimden 1. Gateway GWTC116-2BL Display Replacement: adım 12, 2 resimden 2.
    • Flick open the bracket securing the display cable and disconnect the cable from the motherboard.
  13. Gateway GWTC116-2BL Display Replacement: adım 13, 1 resimden 1.
    • Remove the motherboard from the device.
  14. Gateway GWTC116-2BL Display Replacement, Display: adım 14, 1 resimden 1.
    • Remove seven 3.0 mm Phillips #00 screws from the laptop.
  15. Gateway GWTC116-2BL Display Replacement: adım 15, 1 resimden 1.
    • Applying some force, use your hands to pry the display of the laptop away from the base.
Sonuç
Kailey Sousa
513 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-2, Botvin Spring 2024 UMass Dartmouth, Team 6-2, Botvin Spring 2024 üyesi
UMASSD-BOTVIN-S24S6G2
3 Üyeler
5 adet Kılavuz yazıldı
1Rehber Yorum
Mon écran ne s'allume pas au démarrage. Que faire ?
Youssouf SAWADOGO - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 52
Her zaman: 470
