Ana içeriğe geç
Gateway ID49C07U Keyboard Replacement
Neye ihtiyacın var
  1. Gateway ID49C07U Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the laptop over so the bottom of the device is facing upwards with the hinge facing away from you.
  2. Gateway ID49C07U Keyboard Replacement: adım 2, 2 resimden 1. Gateway ID49C07U Keyboard Replacement: adım 2, 2 resimden 2.
    • Locate the switch on the top left of the laptop labeled with a padlock symbol.
    • Flip the switch in the direction of the unlocked padlock symbol.
  3. Gateway ID49C07U Keyboard Replacement: adım 3, 1 resimden 1.
    • Locate the switch that releases the battery and slide it to the right.
  4. Gateway ID49C07U Keyboard Replacement: adım 4, 1 resimden 1.
    • While holding the release switch to the right, pull the battery away from you.
  5. Gateway ID49C07U Keyboard Replacement, Keyboard: adım 5, 1 resimden 1.
    • Turn the laptop over and open
  6. Gateway ID49C07U Keyboard Replacement: adım 6, 3 resimden 1. Gateway ID49C07U Keyboard Replacement: adım 6, 3 resimden 2. Gateway ID49C07U Keyboard Replacement: adım 6, 3 resimden 3.
    • Use the small metal spudger to push in each of the clips on the keyboard
  7. Gateway ID49C07U Keyboard Replacement: adım 7, 3 resimden 1. Gateway ID49C07U Keyboard Replacement: adım 7, 3 resimden 2. Gateway ID49C07U Keyboard Replacement: adım 7, 3 resimden 3.
    • Continued
  8. Gateway ID49C07U Keyboard Replacement: adım 8, 2 resimden 1. Gateway ID49C07U Keyboard Replacement: adım 8, 2 resimden 2.
    • Use the small spudger to pick up the corner
  9. Gateway ID49C07U Keyboard Replacement: adım 9, 1 resimden 1.
    • Slide keyboard towards the screen
  10. Gateway ID49C07U Keyboard Replacement: adım 10, 2 resimden 1. Gateway ID49C07U Keyboard Replacement: adım 10, 2 resimden 2.
    • Use the small spudger to slide the cable lock up on both sides of the connector and slide the cable out
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Ryan Howlett
273 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S6-G4, Isaacson Spring 2017 UMass Dartmouth, Team S6-G4, Isaacson Spring 2017 üyesi
UMASSD-ISAACSON-S17S6G4
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 650
