Ana içeriğe geç
Gateway ID49C07U Screen Replacement
Neye ihtiyacın var
  1. Gateway ID49C07U Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the laptop over so the bottom of the device is facing upwards with the hinge facing away from you.
  2. Gateway ID49C07U Screen Replacement: adım 2, 2 resimden 1. Gateway ID49C07U Screen Replacement: adım 2, 2 resimden 2.
    • Locate the switch on the top left of the laptop labeled with a padlock symbol.
    • Flip the switch in the direction of the unlocked padlock symbol.
  3. Gateway ID49C07U Screen Replacement: adım 3, 1 resimden 1.
    • Locate the switch that releases the battery and slide it to the right.
  4. Gateway ID49C07U Screen Replacement: adım 4, 1 resimden 1.
    • While holding the release switch to the right, pull the battery away from you.
  5. Gateway ID49C07U Screen Replacement, Screen: adım 5, 1 resimden 1.
    • Turn the laptop over and open.
  6. Gateway ID49C07U Screen Replacement: adım 6, 2 resimden 1. Gateway ID49C07U Screen Replacement: adım 6, 2 resimden 2.
    • Use the Small metal spudger to remove the small black screw covers in the bottom corners of the screen
  7. Gateway ID49C07U Screen Replacement: adım 7, 2 resimden 1. Gateway ID49C07U Screen Replacement: adım 7, 2 resimden 2.
    • Use the PH1 Screwdriver to remove the screws
  8. Gateway ID49C07U Screen Replacement: adım 8, 1 resimden 1.
    • Use the small metal spudger to start separating the front plastic cover from the back plastic cover
  9. Gateway ID49C07U Screen Replacement: adım 9, 3 resimden 1. Gateway ID49C07U Screen Replacement: adım 9, 3 resimden 2. Gateway ID49C07U Screen Replacement: adım 9, 3 resimden 3.
    • Once there is enough room for you to fit your hand underneath the top plastic cover you can start pealing it back. It will make a lot of popping noises as it unclips when you separate it.
  10. Gateway ID49C07U Screen Replacement: adım 10, 3 resimden 1. Gateway ID49C07U Screen Replacement: adım 10, 3 resimden 2. Gateway ID49C07U Screen Replacement: adım 10, 3 resimden 3.
    • Once the plastic cover is off locate the 4 screws in the corners of the screen and unscrew them
  11. Gateway ID49C07U Screen Replacement: adım 11, 2 resimden 1. Gateway ID49C07U Screen Replacement: adım 11, 2 resimden 2.
    • After the screws are out gently flip the screen over onto the keyboard
  12. Gateway ID49C07U Screen Replacement: adım 12, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use the tweezers to peal back the tape over the wire connector on the bottom of the screen
  13. Gateway ID49C07U Screen Replacement: adım 13, 2 resimden 1. Gateway ID49C07U Screen Replacement: adım 13, 2 resimden 2.
    • Hold the tape back with one hand and pull the connector out
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Ryan Howlett
273 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S6-G4, Isaacson Spring 2017 UMass Dartmouth, Team S6-G4, Isaacson Spring 2017 üyesi
UMASSD-ISAACSON-S17S6G4
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 6
Son 30 gün: 13
Her zaman: 357
