Giriş
It is important to have a functioning webcam because it is a useful accessory to have when it comes to tasks like video calls, taking pictures/videos, and so on.
Unlock the button in the top left on the back of the laptop (So the red is showing).
  • Unlock the button in the top left on the back of the laptop (So the red is showing).
Yorum Ekle
The battery should be able to be removed easily now.
  • The battery should be able to be removed easily now.
Yorum Ekle
  • Using the Phillips #0 screwdriver, remove six (6) 5mm screws, two (2) 17.5mm screws, and three (3) 2.5mm screws from the back cover, as marked here.
Yorum Ekle
  • Pry off the keyboard by placing your plastic opening tool on the center of the top row of keys, as shown in the photograph.
  • If the plastic opening tool bends or slips, use something sturdier, such as the Phillips #0 screwdriver.
  • Remove the keyboard.
Yorum Ekle
  • Remove the five (5) 5mm screws shown here using the Phillips #0 screwdriver.
Yorum Ekle
  • Separate the upper cover from the back cover. It is possible to do this without a tool, but you may also use a plastic opening tool for added leverage.
  • Be careful to keep even pressure all the way around the cover so that it is not bent beyond repair.
Yorum Ekle
  • Pry the border around the monitor off of the top cover using a plastic opening tool, as shown.
  • Be careful not to damage the computer screen in the process.
Yorum Ekle
  • Separate the monitor from the border cover once all snap connections have been pried apart.
Yorum Ekle
  • Remove the six (6) 5mm screws shown here using the Phillips #0 screwdriver.
Yorum Ekle
  • Take the screen out of the top cover.
Yorum Ekle
  • Disconnect the webcam from the wires attaching it to the computer.
  • Lift the webcam away from the top cover.
Yorum Ekle
Sonuç
Brian
201 İtibar
2 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team 3-2, Calaway Spring 2014 UMass Dartmouth, Team 3-2, Calaway Spring 2014 üyesi
UMASSD-CALAWAY-S14S3G2
4 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 2
Her zaman: 105
