Giriş
This is a repair guide on how to remove the cooling fan. Reasons to replace this part are it is making a lot of noise, it is damaged, it may have melted fem overuse of the lap top, or the software the computer is running is too powerful.
Unlock the button in the top left on the back of the laptop (So the red is showing).
  • Unlock the button in the top left on the back of the laptop (So the red is showing).
Yorum Ekle
The battery should be able to be removed easily now.
  • The battery should be able to be removed easily now.
Yorum Ekle
Remove all 11 of the screw shown on the bottom of the lap top using the specified screw driver. Remove all 11 of the screw shown on the bottom of the lap top using the specified screw driver.
  • Remove all 11 of the screw shown on the bottom of the lap top using the specified screw driver.
Yorum Ekle
Lift off the keyboard by doing exactly what is shown in the first picture. Get the head of the plastic opening tool under and then wedge it out. Lift off the keyboard by doing exactly what is shown in the first picture. Get the head of the plastic opening tool under and then wedge it out. Lift off the keyboard by doing exactly what is shown in the first picture. Get the head of the plastic opening tool under and then wedge it out.
  • Lift off the keyboard by doing exactly what is shown in the first picture. Get the head of the plastic opening tool under and then wedge it out.
Yorum Ekle
Remove the 5 circled screws with the Phillips #0 screw driver. Carefully separate the back cover from the front either using your hands or a plastic opening tool. Carefully separate the back cover from the front either using your hands or a plastic opening tool.
  • Remove the 5 circled screws with the Phillips #0 screw driver.
  • Carefully separate the back cover from the front either using your hands or a plastic opening tool.
Yorum Ekle
Unscrew this 1 screw to remove the wifi card. Then unplug the wires it is attached to and take it out.
  • Unscrew this 1 screw to remove the wifi card.
  • Then unplug the wires it is attached to and take it out.
Yorum Ekle
Use the phillps #00 screw driver to remove these 3 small scows so the motherboard can be removed. Then remove it from the base of th computer.
  • Use the phillps #00 screw driver to remove these 3 small scows so the motherboard can be removed.
  • Then remove it from the base of th computer.
Yorum Ekle
Use the Phillips #00 screw driver to remove the 4 circled screws.
  • Use the Phillips #00 screw driver to remove the 4 circled screws.
Yorum Ekle
Disconnect the wires from the motherboard.
  • Disconnect the wires from the motherboard.
  • The fan should now be fully disconnected and ready to replace.
Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kyle
622 İtibar
10 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team 3-2, Calaway Spring 2014 UMass Dartmouth, Team 3-2, Calaway Spring 2014 üyesi
UMASSD-CALAWAY-S14S3G2
4 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 1
Tüm Zamanlar: 145
