Ana içeriğe geç
Gateway KAV60 LT2016U Hard Drive Replacement
Neye ihtiyacın var
  1. Gateway KAV60 LT2016U Hard Drive Replacement, Battery: adım 1, 3 resimden 1. Gateway KAV60 LT2016U Hard Drive Replacement, Battery: adım 1, 3 resimden 2. Gateway KAV60 LT2016U Hard Drive Replacement, Battery: adım 1, 3 resimden 3.
    • Unlock the tab located in the top left corner of the netbook.
    • The red tab indicated that the battery has been properly unlocked.
    • Remove the battery.
    • When working with electronics, it is always wise to remove the power source before taking the device apart.
  2. Gateway KAV60 LT2016U Hard Drive Replacement, Hard Drive: adım 2, 1 resimden 1.
    • The hard drive is located under this cover.
  3. Gateway KAV60 LT2016U Hard Drive Replacement: adım 3, 2 resimden 1. Gateway KAV60 LT2016U Hard Drive Replacement: adım 3, 2 resimden 2.
    • Remove the two (2) 5mm screws holding the cover down using the Phillips #0 screwdriver.
  4. Gateway KAV60 LT2016U Hard Drive Replacement: adım 4, 2 resimden 1. Gateway KAV60 LT2016U Hard Drive Replacement: adım 4, 2 resimden 2.
    • Use a plastic opening tool to lift the cover.
  5. Gateway KAV60 LT2016U Hard Drive Replacement: adım 5, 1 resimden 1.
    • Using a Phillips #0 screwdriver, remove a third 5mm screw that holds the second cover that is directly protecting the hard drive.
  6. Gateway KAV60 LT2016U Hard Drive Replacement: adım 6, 3 resimden 1. Gateway KAV60 LT2016U Hard Drive Replacement: adım 6, 3 resimden 2. Gateway KAV60 LT2016U Hard Drive Replacement: adım 6, 3 resimden 3.
    • Slide the silver cover up; the hole on the cover and the hole for the screw will no longer match up.
    • Lift the silver cover; this will expose the hard drive.
Sonuç
Lydia Benjock
1.216 İtibar
10 adet Kılavuz yazıldı
Ekip
Clemson, Team 14-3, Benson Fall 2013 Clemson, Team 14-3, Benson Fall 2013 üyesi
CLEM-BENSON-F13S14G3
3 Üyeler
22 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 10
Her zaman: 1,705
