Giriş
This is a guide on how to remove the hard drive on this lap top. Reasons for removal of the hard drive are the current one has stopped working, or to get upgrade to a more improved hard drive.
Unlock the button in the top left on the back of the laptop (So the red is showing).
  • Unlock the button in the top left on the back of the laptop (So the red is showing).
Yorum Ekle
The battery should be able to be removed easily now.
  • The battery should be able to be removed easily now.
Yorum Ekle
The hard drive is located on the bottom of the laptop on the left hand side.
  • The hard drive is located on the bottom of the laptop on the left hand side.
Yorum Ekle
Remove the two scores on the cover with the screwdriver specified.
  • Remove the two scores on the cover with the screwdriver specified.
Yorum Ekle
Lift off the cover with the plastic opener.
  • Lift off the cover with the plastic opener.
Yorum Ekle
Unscrew the one screw holding the hard drive in place with the same screw driver.
  • Unscrew the one screw holding the hard drive in place with the same screw driver.
Yorum Ekle
Slide the hard drive up and remove it from the laptop.
  • Slide the hard drive up and remove it from the laptop.
Yorum Ekle
Sonuç
2 başka kişi bu kılavuzu tamamladı.
Kyle
622 İtibar
10 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team 3-2, Calaway Spring 2014 UMass Dartmouth, Team 3-2, Calaway Spring 2014 üyesi
UMASSD-CALAWAY-S14S3G2
4 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 3
Her zaman: 243
