Ana içeriğe geç
Gateway KAV60 LT2016U Key Replacement
Neye ihtiyacın var
  1. Gateway KAV60 LT2016U Key Replacement, Battery: adım 1, 3 resimden 1. Gateway KAV60 LT2016U Key Replacement, Battery: adım 1, 3 resimden 2. Gateway KAV60 LT2016U Key Replacement, Battery: adım 1, 3 resimden 3.
    • Unlock the tab located in the top left corner of the netbook.
    • The red tab indicated that the battery has been properly unlocked.
    • Remove the battery.
    • When working with electronics, it is always wise to remove the power source before taking the device apart.
  2. Gateway KAV60 LT2016U Key Replacement, Key: adım 2, 2 resimden 1. Gateway KAV60 LT2016U Key Replacement, Key: adım 2, 2 resimden 2.
    • Any key on the keyboard can be replaced.
    • Insert the plastic opening tool under the key to be replaced.
  3. Gateway KAV60 LT2016U Key Replacement: adım 3, 1 resimden 1.
    • The key is easily removed by applying force to the plastic opening tool until the key pops off.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Lydia Benjock
1.216 İtibar
10 adet Kılavuz yazıldı
Ekip
Clemson, Team 14-3, Benson Fall 2013 Clemson, Team 14-3, Benson Fall 2013 üyesi
CLEM-BENSON-F13S14G3
3 Üyeler
22 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 8
Her zaman: 768
