Giriş
Keys are easy to replace on a Gateway netbook. You can purchase keys online at Amazon, eBay, or the product page. Keys contain three parts: key cap, key retainer clip, and rubber cup. For this guide, we will replace the key cap.
Before replacing any key, make sure your netbook is turned off to prevent any mistakes during the process.
  • Before replacing any key, make sure your netbook is turned off to prevent any mistakes during the process.
Yorum Ekle
Insert a plastic opening tool under the key to be removed. Insert a plastic opening tool under the key to be removed.
  • Insert a plastic opening tool under the key to be removed.
Yorum Ekle
Put the opening tool underneath the key. Use force until the key pops up.
  • Put the opening tool underneath the key. Use force until the key pops up.
Yorum Ekle
  • To replace the key, follow these instructions, but do them in reverse order (i.e., use the plastic opening tool to put the key back in place).
Yorum Ekle
Sonuç
My Linh Pham
301 İtibar
3 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team 3-2, Calaway Spring 2014 UMass Dartmouth, Team 3-2, Calaway Spring 2014 üyesi
UMASSD-CALAWAY-S14S3G2
4 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 1
Tüm Zamanlar: 230
