Ana içeriğe geç
Gateway KAV60 LT2016U LCD Replacement
Neye ihtiyacın var
    1. Gateway KAV60 LT2016U LCD Replacement, Battery: adım 1, 3 resimden 1. Gateway KAV60 LT2016U LCD Replacement, Battery: adım 1, 3 resimden 2. Gateway KAV60 LT2016U LCD Replacement, Battery: adım 1, 3 resimden 3.
      • Unlock the tab located in the top left corner of the netbook.
      • The red tab indicated that the battery has been properly unlocked.
      • Remove the battery.
      • When working with electronics, it is always wise to remove the power source before taking the device apart.
      FixBot'a Sor
      Yorum Ekle
    1. Gateway KAV60 LT2016U LCD Replacement, Upper Cover: adım 2, 1 resimden 1.
      • Make sure the RAM, hard drive, and WiFi card have been removed from the computer before trying to take off the cover so they are not damaged in the process.
      FixBot'a Sor
      Yorum Ekle
    2. Gateway KAV60 LT2016U LCD Replacement: adım 3, 2 resimden 1. Gateway KAV60 LT2016U LCD Replacement: adım 3, 2 resimden 2.
      • Remove six (6) 5mm screws, two (2) 17.5mm screws, and three (3) 2.5mm screws from the back, using the Phillips #0 screwdriver, as marked here.
      FixBot'a Sor
      Yorum Ekle
    3. Gateway KAV60 LT2016U LCD Replacement: adım 4, 3 resimden 1. Gateway KAV60 LT2016U LCD Replacement: adım 4, 3 resimden 2. Gateway KAV60 LT2016U LCD Replacement: adım 4, 3 resimden 3.
      • Pry up the keyboard using a spudger or plastic opening tool in the exact location shown in the photograph.
      • Don't use a screwdriver as a pry tool as shown in this example.
      • Carefully disconnect the keyboard ribbon cable from the motherboard, and remove the keyboard.
      FixBot'a Sor
      Yorum Ekle
    4. Gateway KAV60 LT2016U LCD Replacement: adım 5, 1 resimden 1.
      • Remove the five (5) 5mm screws shown here using the Phillips #0 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    5. Gateway KAV60 LT2016U LCD Replacement: adım 6, 2 resimden 1. Gateway KAV60 LT2016U LCD Replacement: adım 6, 2 resimden 2.
      • Separate the upper cover from the back cover. It is possible to do this without a tool, but you may also use a plastic opening tool for added leverage.
      • Be careful to keep even pressure all the way around the cover so that it is not bent beyond repair.
      • Carefully disconnect two ribbon cables to complete the separation of the upper cover.
      FixBot'a Sor
      Yorum Ekle
    1. Gateway KAV60 LT2016U LCD Replacement, LCD: adım 7, 3 resimden 1. Gateway KAV60 LT2016U LCD Replacement, LCD: adım 7, 3 resimden 2. Gateway KAV60 LT2016U LCD Replacement, LCD: adım 7, 3 resimden 3.
      • Pry the border around the monitor off of the top cover using a plastic opening tool, as shown.
      • Be careful not to damage the computer screen in the process
      FixBot'a Sor
      Yorum Ekle
    2. Gateway KAV60 LT2016U LCD Replacement: adım 8, 2 resimden 1. Gateway KAV60 LT2016U LCD Replacement: adım 8, 2 resimden 2.
      • Separate the monitor from the border cover once all snap connections have been pried apart.
      FixBot'a Sor
      Yorum Ekle
    3. Gateway KAV60 LT2016U LCD Replacement: adım 9, 1 resimden 1.
      • Remove the six (6) 5mm screws shown here using the Phillips #0 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    4. Gateway KAV60 LT2016U LCD Replacement: adım 10, 2 resimden 1. Gateway KAV60 LT2016U LCD Replacement: adım 10, 2 resimden 2.
      • Take the screen out of the top cover.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Lydia Benjock
1.240 İtibar
10 adet Kılavuz yazıldı
Ekip
Clemson, Team 14-3, Benson Fall 2013 Clemson, Team 14-3, Benson Fall 2013 üyesi
CLEM-BENSON-F13S14G3
3 Üyeler
132 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 31
Son 30 gün: 59
Her zaman: 1,993
