Ana içeriğe geç
Gateway KAV60 LT2016U RAM Replacement
Neye ihtiyacın var
  1. Gateway KAV60 LT2016U RAM Replacement, Battery: adım 1, 3 resimden 1. Gateway KAV60 LT2016U RAM Replacement, Battery: adım 1, 3 resimden 2. Gateway KAV60 LT2016U RAM Replacement, Battery: adım 1, 3 resimden 3.
    • Unlock the tab located in the top left corner of the netbook.
    • The red tab indicated that the battery has been properly unlocked.
    • Remove the battery.
    • When working with electronics, it is always wise to remove the power source before taking the device apart.
  2. Gateway KAV60 LT2016U RAM Replacement, RAM: adım 2, 1 resimden 1.
    • The RAM is located under this cover.
  3. Gateway KAV60 LT2016U RAM Replacement: adım 3, 3 resimden 1. Gateway KAV60 LT2016U RAM Replacement: adım 3, 3 resimden 2. Gateway KAV60 LT2016U RAM Replacement: adım 3, 3 resimden 3.
    • Using a Phillips #0 screwdriver, remove one (1) 5mm screw holding the cover in place.
    • Use a plastic opening tool to remove the cover.
  4. Gateway KAV60 LT2016U RAM Replacement: adım 4, 2 resimden 1. Gateway KAV60 LT2016U RAM Replacement: adım 4, 2 resimden 2.
    • Unlock the RAM by pinching the metal clamps that keep the RAM in place.
    • Remove the RAM while the metal clamps are disengaged.
Sonuç
Lydia Benjock
1.216 İtibar
10 adet Kılavuz yazıldı
Ekip
Clemson, Team 14-3, Benson Fall 2013 Clemson, Team 14-3, Benson Fall 2013 üyesi
CLEM-BENSON-F13S14G3
3 Üyeler
22 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 2,167
