Unlock the button in the top left on the back of the laptop (So the red is showing).
  • Unlock the button in the top left on the back of the laptop (So the red is showing).
Yorum Ekle
The battery should be able to be removed easily now.
  • The battery should be able to be removed easily now.
Yorum Ekle
The RAM is located under this cover.
  • The RAM is located under this cover.
Yorum Ekle
Using a Phillips #0 screwdriver, remove one (1) 5mm screw holding the cover in place. Use a plastic opening tool to remove the cover. Try opening tools of different sizes to find one that will easily open the cover. Use a plastic opening tool to remove the cover. Try opening tools of different sizes to find one that will easily open the cover.
  • Using a Phillips #0 screwdriver, remove one (1) 5mm screw holding the cover in place.
  • Use a plastic opening tool to remove the cover. Try opening tools of different sizes to find one that will easily open the cover.
Yorum Ekle
Unlock the RAM by pinching the metal clamps that keep the RAM in place. Remove the RAM while the metal clamps are disengaged. Use two opening tools, positioned on each side of the RAM, and push outwards to remove the RAM.
  • Unlock the RAM by pinching the metal clamps that keep the RAM in place.
  • Remove the RAM while the metal clamps are disengaged. Use two opening tools, positioned on each side of the RAM, and push outwards to remove the RAM.
Yorum Ekle
Sonuç
Emily
301 İtibar
3 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team 3-2, Calaway Spring 2014 UMass Dartmouth, Team 3-2, Calaway Spring 2014 üyesi
UMASSD-CALAWAY-S14S3G2
4 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 1
Her zaman: 105
