Ana içeriğe geç
Gateway KAV60 LT2016U Speaker Replacement
Neye ihtiyacın var
  1. Gateway KAV60 LT2016U Speaker Replacement, Battery: adım 1, 3 resimden 1. Gateway KAV60 LT2016U Speaker Replacement, Battery: adım 1, 3 resimden 2. Gateway KAV60 LT2016U Speaker Replacement, Battery: adım 1, 3 resimden 3.
    • Unlock the tab located in the top left corner of the netbook.
    • The red tab indicated that the battery has been properly unlocked.
    • Remove the battery.
    • When working with electronics, it is always wise to remove the power source before taking the device apart.
  2. Gateway KAV60 LT2016U Speaker Replacement, Upper Cover: adım 2, 1 resimden 1.
    • Make sure the RAM, hard drive, and WiFi card have been removed from the computer before trying to take off the cover so they are not damaged in the process.
  3. Gateway KAV60 LT2016U Speaker Replacement: adım 3, 2 resimden 1. Gateway KAV60 LT2016U Speaker Replacement: adım 3, 2 resimden 2.
    • Remove six (6) 5mm screws, two (2) 17.5mm screws, and three (3) 2.5mm screws from the back, using the Phillips #0 screwdriver, as marked here.
  4. Gateway KAV60 LT2016U Speaker Replacement: adım 4, 3 resimden 1. Gateway KAV60 LT2016U Speaker Replacement: adım 4, 3 resimden 2. Gateway KAV60 LT2016U Speaker Replacement: adım 4, 3 resimden 3.
    • Pry up the keyboard using a spudger or plastic opening tool in the exact location shown in the photograph.
    • Don't use a screwdriver as a pry tool as shown in this example.
    • Carefully disconnect the keyboard ribbon cable from the motherboard, and remove the keyboard.
  5. Gateway KAV60 LT2016U Speaker Replacement: adım 5, 1 resimden 1.
    • Remove the five (5) 5mm screws shown here using the Phillips #0 screwdriver.
  6. Gateway KAV60 LT2016U Speaker Replacement: adım 6, 2 resimden 1. Gateway KAV60 LT2016U Speaker Replacement: adım 6, 2 resimden 2.
    • Separate the upper cover from the back cover. It is possible to do this without a tool, but you may also use a plastic opening tool for added leverage.
    • Be careful to keep even pressure all the way around the cover so that it is not bent beyond repair.
    • Carefully disconnect two ribbon cables to complete the separation of the upper cover.
  7. Gateway KAV60 LT2016U Speaker Replacement, Speaker: adım 7, 2 resimden 1. Gateway KAV60 LT2016U Speaker Replacement, Speaker: adım 7, 2 resimden 2.
    • Remove the 5mm screw of the left speaker cover using a Phillips #0 screwdriver, as shown here.
  8. Gateway KAV60 LT2016U Speaker Replacement: adım 8, 1 resimden 1.
    • Disconnect the speaker's connection to the motherboard by lightly pulling on the connector until it pops apart from the motherboard.
  9. Gateway KAV60 LT2016U Speaker Replacement: adım 9, 2 resimden 1. Gateway KAV60 LT2016U Speaker Replacement: adım 9, 2 resimden 2.
    • Repeat the previous steps for the right speaker. Remove the 5mm screw of the right speaker cover using a Phillips #0 screwdriver.
Sonuç
Lydia Benjock
1.216 İtibar
10 adet Kılavuz yazıldı
Ekip
Clemson, Team 14-3, Benson Fall 2013 Clemson, Team 14-3, Benson Fall 2013 üyesi
CLEM-BENSON-F13S14G3
3 Üyeler
22 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 487
