Giriş
This guide will show the steps required to remove a broken speaker from the netbook, and replace it with a new speaker.
Unlock the button in the top left on the back of the laptop (So the red is showing).
  • Unlock the button in the top left on the back of the laptop (So the red is showing).
Yorum Ekle
The battery should be able to be removed easily now.
  • The battery should be able to be removed easily now.
Yorum Ekle
Using the Phillips #0 screwdriver, remove six (6) 5mm screws, two (2) 17.5mm screws, and three (3) 2.5mm screws from the back cover, as marked here. Using the Phillips #0 screwdriver, remove six (6) 5mm screws, two (2) 17.5mm screws, and three (3) 2.5mm screws from the back cover, as marked here.
  • Using the Phillips #0 screwdriver, remove six (6) 5mm screws, two (2) 17.5mm screws, and three (3) 2.5mm screws from the back cover, as marked here.
Yorum Ekle
Pry off the keyboard by placing your plastic opening tool on the center of the top row of keys, as shown in the photograph. If the plastic opening tool bends or slips, use something sturdier, such as the Phillips #0 screwdriver. Remove the keyboard.
  • Pry off the keyboard by placing your plastic opening tool on the center of the top row of keys, as shown in the photograph.
  • If the plastic opening tool bends or slips, use something sturdier, such as the Phillips #0 screwdriver.
  • Remove the keyboard.
Yorum Ekle
Remove the five (5) 5mm screws shown here using the Phillips #0 screwdriver.
  • Remove the five (5) 5mm screws shown here using the Phillips #0 screwdriver.
Yorum Ekle
Separate the upper cover from the back cover. It is possible to do this without a tool, but you may also use a plastic opening tool for added leverage. Be careful to keep even pressure all the way around the cover so that it is not bent beyond repair.
  • Separate the upper cover from the back cover. It is possible to do this without a tool, but you may also use a plastic opening tool for added leverage.
  • Be careful to keep even pressure all the way around the cover so that it is not bent beyond repair.
Yorum Ekle
Remove the 5mm screw of the left speaker cover using a Phillips #0 screwdriver, as shown here. Remove the 5mm screw of the left speaker cover using a Phillips #0 screwdriver, as shown here.
  • Remove the 5mm screw of the left speaker cover using a Phillips #0 screwdriver, as shown here.
Yorum Ekle
Disconnect the speaker's connection to the motherboard by lightly pulling on the connector until it pops apart from the motherboard.
  • Disconnect the speaker's connection to the motherboard by lightly pulling on the connector until it pops apart from the motherboard.
Yorum Ekle
Repeat the previous steps for the right speaker. Remove the 5mm screw of the right speaker cover using a Phillips #0 screwdriver. Repeat the previous steps for the right speaker. Remove the 5mm screw of the right speaker cover using a Phillips #0 screwdriver.
  • Repeat the previous steps for the right speaker. Remove the 5mm screw of the right speaker cover using a Phillips #0 screwdriver.
Yorum Ekle
Yorum Ekle
Yorum Ekle
Sonuç
Emily
301 İtibar
3 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team 3-2, Calaway Spring 2014 UMass Dartmouth, Team 3-2, Calaway Spring 2014 üyesi
UMASSD-CALAWAY-S14S3G2
4 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Tüm Zamanlar: 80
