Ana içeriğe geç
Gateway LT2104u RAM Replacement Guide
Neye ihtiyacın var
  1. Gateway LT2104u RAM Replacement Guide, RAM: adım 1, 1 resimden 1.
    • Locate the the "L" shaped cover on the back, lower right hand side the device. Using a Philips screwdriver, remove the screw holding it in.
    FixBot'a Sor
    Yorum Ekle
  2. Gateway LT2104u RAM Replacement Guide: adım 2, 2 resimden 1. Gateway LT2104u RAM Replacement Guide: adım 2, 2 resimden 2.
    • Gently lift the cover until it detaches from the device.
    FixBot'a Sor
    Yorum Ekle
  3. Gateway LT2104u RAM Replacement Guide: adım 3, 2 resimden 1. Gateway LT2104u RAM Replacement Guide: adım 3, 2 resimden 2.
    • Gently push the levers on each side of the stick of RAM away from each other until the RAM springs into a 45° angle.
    FixBot'a Sor
    Yorum Ekle
  4. Gateway LT2104u RAM Replacement Guide: adım 4, 1 resimden 1.
    • Carefully remove the stick of RAM by pulling at the same 45° angle the RAM is currently at until it detaches from the device.
    FixBot'a Sor
    Yorum Ekle
  5. Gateway LT2104u RAM Replacement Guide: adım 5, 1 resimden 1.
    • When inserting the new stick of ram, be sure to insert it at the same 45° angle that the old stick of ram was taken out at. Press the stick of RAM down until it clicks into place.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Chris Sullivan
234 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 7-5, Catania Spring 2016 UMass Dartmouth, Team 7-5, Catania Spring 2016 üyesi
UMASSD-CATANIA-S16S7G5
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 22
Her zaman: 602
