Ana içeriğe geç
Gateway LT4004u Screen Replacement
Neye ihtiyacın var
  1. Gateway LT4004u Screen Replacement, Screen: adım 1, 3 resimden 1. Gateway LT4004u Screen Replacement, Screen: adım 1, 3 resimden 2. Gateway LT4004u Screen Replacement, Screen: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Open the laptop so that the screen and keyboard are facing you.
    • Remove the two screw covers at the bottom right and left corners of the screen using tweezers.
    FixBot'a Sor
    Yorum Ekle
  2. Gateway LT4004u Screen Replacement: adım 2, 3 resimden 1. Gateway LT4004u Screen Replacement: adım 2, 3 resimden 2. Gateway LT4004u Screen Replacement: adım 2, 3 resimden 3.
    • Unscrew the two 5.0mm screws underneath the screen covers on the left and right side and remove them from the laptop. For this step and the following steps, use a Phillips #0 head screwdriver.
    FixBot'a Sor
    Yorum Ekle
  3. Gateway LT4004u Screen Replacement: adım 3, 3 resimden 1. Gateway LT4004u Screen Replacement: adım 3, 3 resimden 2. Gateway LT4004u Screen Replacement: adım 3, 3 resimden 3.
    • Once the two screws are removed, pry the screen casing away from the screen. You can use your fingernails or a tool such as tweezers to separate the screen casing from the backing.
    • Be prepared to hear cracking noises. These are expected.
    • Unhook the screen casing at the bottom of the screen from the central hinges on the left and right side connecting the screen casing to the keyboard.
    • Remove the screen casing.
    FixBot'a Sor
    Yorum Ekle
  4. Gateway LT4004u Screen Replacement: adım 4, 3 resimden 1. Gateway LT4004u Screen Replacement: adım 4, 3 resimden 2. Gateway LT4004u Screen Replacement: adım 4, 3 resimden 3.
    • Once the screen casing is removed, unscrew the 8 screws surrounding the screen and remove them from the laptop. All 8 screws should measure 4.0mm long.
    • There is a single screw in each red indicator and two screws in each orange indicator, totaling to the eight screws.
    FixBot'a Sor
    Yorum Ekle
  5. Gateway LT4004u Screen Replacement: adım 5, 3 resimden 1. Gateway LT4004u Screen Replacement: adım 5, 3 resimden 2. Gateway LT4004u Screen Replacement: adım 5, 3 resimden 3.
    • Unplug the webcam connection from the top of the laptop screen backing.
    FixBot'a Sor
    Yorum Ekle
  6. Gateway LT4004u Screen Replacement: adım 6, 3 resimden 1. Gateway LT4004u Screen Replacement: adım 6, 3 resimden 2. Gateway LT4004u Screen Replacement: adım 6, 3 resimden 3.
    • Flip the screen over so that it is lying on top of the keyboard.
    • Looking at the underside of the screen, remove the yellow tape and carefully remove the wires attaching the screen to the laptop.
    FixBot'a Sor
    Yorum Ekle
  7. Gateway LT4004u Screen Replacement: adım 7, 1 resimden 1.
    • Remove the screen from the rest of the laptop.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Carlisle Hiott
821 İtibar
7 adet Kılavuz yazıldı
Ekip
Clemson, Team 6-5, Benson Spring 2016 Clemson, Team 6-5, Benson Spring 2016 üyesi
CLEM-BENSON-S16S6G5
4 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 34
Her zaman: 965
