Ana içeriğe geç
Gateway LT4004u Screen Replacement
  1. Gateway LT4004u Screen Replacement, Screen: adım 1, 3 resimden 1. Gateway LT4004u Screen Replacement, Screen: adım 1, 3 resimden 2. Gateway LT4004u Screen Replacement, Screen: adım 1, 3 resimden 3.
    • Open the laptop so that the screen and keyboard are facing you.
    • Remove the two screw covers at the bottom right and left corners of the screen using tweezers.
  2. Gateway LT4004u Screen Replacement: adım 2, 3 resimden 1. Gateway LT4004u Screen Replacement: adım 2, 3 resimden 2. Gateway LT4004u Screen Replacement: adım 2, 3 resimden 3.
    • Unscrew the two 5.0mm screws underneath the screen covers on the left and right side and remove them from the laptop. For this step and the following steps, use a Phillips #0 head screwdriver.
  3. Gateway LT4004u Screen Replacement: adım 3, 3 resimden 1. Gateway LT4004u Screen Replacement: adım 3, 3 resimden 2. Gateway LT4004u Screen Replacement: adım 3, 3 resimden 3.
    • Once the two screws are removed, pry the screen casing away from the screen. You can use your fingernails or a tool such as tweezers to separate the screen casing from the backing.
    • Be prepared to hear cracking noises. These are expected.
    • Unhook the screen casing at the bottom of the screen from the central hinges on the left and right side connecting the screen casing to the keyboard.
    • Remove the screen casing.
  4. Gateway LT4004u Screen Replacement: adım 4, 3 resimden 1. Gateway LT4004u Screen Replacement: adım 4, 3 resimden 2. Gateway LT4004u Screen Replacement: adım 4, 3 resimden 3.
    • Once the screen casing is removed, unscrew the 8 screws surrounding the screen and remove them from the laptop. All 8 screws should measure 4.0mm long.
    • There is a single screw in each red indicator and two screws in each orange indicator, totaling to the eight screws.
  5. Gateway LT4004u Screen Replacement: adım 5, 3 resimden 1. Gateway LT4004u Screen Replacement: adım 5, 3 resimden 2. Gateway LT4004u Screen Replacement: adım 5, 3 resimden 3.
    • Unplug the webcam connection from the top of the laptop screen backing.
  6. Gateway LT4004u Screen Replacement: adım 6, 3 resimden 1. Gateway LT4004u Screen Replacement: adım 6, 3 resimden 2. Gateway LT4004u Screen Replacement: adım 6, 3 resimden 3.
    • Flip the screen over so that it is lying on top of the keyboard.
    • Looking at the underside of the screen, remove the yellow tape and carefully remove the wires attaching the screen to the laptop.
  7. Gateway LT4004u Screen Replacement: adım 7, 1 resimden 1.
    • Remove the screen from the rest of the laptop.
Sonuç
Carlisle Hiott
803 İtibar
7 adet Kılavuz yazıldı
Clemson, Team 6-5, Benson Spring 2016 Clemson, Team 6-5, Benson Spring 2016 üyesi
CLEM-BENSON-S16S6G5
4 Üyeler
16 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 10
Her zaman: 400
