Ana içeriğe geç
Gateway LT41P10u Monitor Replacement
Neye ihtiyacın var
  1. Gateway LT41P10u Monitor Replacement, Battery: adım 1, 1 resimden 1.
    • Place the laptop upside down on a flat surface so you can see the battery.
    FixBot'a Sor
    Yorum Ekle
  2. Gateway LT41P10u Monitor Replacement: adım 2, 1 resimden 1.
    • Pull the two marked tabs towards the outside of the computer to unlock them.
    FixBot'a Sor
    Yorum Ekle
  3. Gateway LT41P10u Monitor Replacement: adım 3, 1 resimden 1.
    • While keeping both of the tabs in the unlocked position, grab the battery and pull outwards, until the battery slides out from the rest of the computer.
    FixBot'a Sor
    Yorum Ekle
  4. Gateway LT41P10u Monitor Replacement, Monitor: adım 4, 2 resimden 1. Gateway LT41P10u Monitor Replacement, Monitor: adım 4, 2 resimden 2.
    • Carefully use a spudger to separate the monitor from top panel.
    • Gently remove lower hooks from the hinges. (see second image)
    FixBot'a Sor
    Yorum Ekle
  5. Gateway LT41P10u Monitor Replacement: adım 5, 2 resimden 1. Gateway LT41P10u Monitor Replacement: adım 5, 2 resimden 2.
    • Once you completed separating the monitor from the top panel disconnect the cable shown here in red by raising the cable lock and pulling the wires away.
    • The second image is how it should look once completely disconnected.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reinstall your device, follow these instructions in reverse order.
Michael Smith
401 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S66-G8, Rockett Fall 2017 UMass Dartmouth, Team S66-G8, Rockett Fall 2017 üyesi
UMASSD-ROCKETT-F17S66G8
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 23
Her zaman: 523
