Ana içeriğe geç
Gateway LT41P10u Webcam Replacement
Neye ihtiyacın var
  1. Gateway LT41P10u Webcam Replacement, Battery: adım 1, 1 resimden 1.
    • Place the laptop upside down on a flat surface so you can see the battery.
    FixBot'a Sor
    Yorum Ekle
  2. Gateway LT41P10u Webcam Replacement: adım 2, 1 resimden 1.
    • Pull the two marked tabs towards the outside of the computer to unlock them.
    FixBot'a Sor
    Yorum Ekle
  3. Gateway LT41P10u Webcam Replacement: adım 3, 1 resimden 1.
    • While keeping both of the tabs in the unlocked position, grab the battery and pull outwards, until the battery slides out from the rest of the computer.
    FixBot'a Sor
    Yorum Ekle
  4. Gateway LT41P10u Webcam Replacement, Monitor: adım 4, 2 resimden 1. Gateway LT41P10u Webcam Replacement, Monitor: adım 4, 2 resimden 2.
    • Carefully use a spudger to separate the monitor from top panel.
    • Gently remove lower hooks from the hinges. (see second image)
    FixBot'a Sor
    Yorum Ekle
  5. Gateway LT41P10u Webcam Replacement: adım 5, 2 resimden 1. Gateway LT41P10u Webcam Replacement: adım 5, 2 resimden 2.
    • Once you completed separating the monitor from the top panel disconnect the cable shown here in red by raising the cable lock and pulling the wires away.
    • The second image is how it should look once completely disconnected.
    FixBot'a Sor
    Yorum Ekle
  6. Gateway LT41P10u Webcam Replacement, Webcam: adım 6, 1 resimden 1.
    • Using a plastic spudger or fingers gently remove webcam hardware from front screen. A gentle heat source can be used to easily remove glued down parts.
    • Once webcam hardware is removed from front screen, it can be removed by hand from the wiring and replaced.
    • Perform these steps carefully as smaller parts are more likely to break.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Patrick Raposo
201 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S66-G8, Rockett Fall 2017 UMass Dartmouth, Team S66-G8, Rockett Fall 2017 üyesi
UMASSD-ROCKETT-F17S66G8
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 21
Her zaman: 359
