Ana içeriğe geç
Gateway Lt4004u Back Panel Replacement
Neye ihtiyacın var
  1. Gateway Lt4004u Back Panel Replacement, Battery: adım 1, 3 resimden 1. Gateway Lt4004u Back Panel Replacement, Battery: adım 1, 3 resimden 2. Gateway Lt4004u Back Panel Replacement, Battery: adım 1, 3 resimden 3.
    • Place the laptop face down in front of you.
    • Locate the battery lock switches on the left and right top corners of the bottom of the device indicated by the red circles.
    • Pinch the switches and slide toward the edges of the computer to unlock.
    FixBot'a Sor
    Yorum Ekle
  2. Gateway Lt4004u Back Panel Replacement: adım 2, 2 resimden 1. Gateway Lt4004u Back Panel Replacement: adım 2, 2 resimden 2.
    • Once the switches have both been unlocked, push the battery upwards away from the rest of the laptop.
    • Remove the battery from the laptop.
    FixBot'a Sor
    Yorum Ekle
  3. Gateway Lt4004u Back Panel Replacement, Keyboard: adım 3, 3 resimden 1. Gateway Lt4004u Back Panel Replacement, Keyboard: adım 3, 3 resimden 2. Gateway Lt4004u Back Panel Replacement, Keyboard: adım 3, 3 resimden 3.
    • Open the laptop so that the screen and keyboard are facing you.
    • Identify the 5 tabs above the function keys in the crevice that attaches the keyboard to the main frame.
    FixBot'a Sor
    Yorum Ekle
  4. Gateway Lt4004u Back Panel Replacement: adım 4, 3 resimden 1. Gateway Lt4004u Back Panel Replacement: adım 4, 3 resimden 2. Gateway Lt4004u Back Panel Replacement: adım 4, 3 resimden 3.
    • Use an opening pick to push each tab away from you.
    • Use an opening tool to push the middle tab until you hear a click. Begin to push the tool downward into the computer and slide the card along the length of the keyboard, as you overcome the five tabs.
    • A clicking sound is normal and no cause for alarm.
    FixBot'a Sor
    Yorum Ekle
  5. Gateway Lt4004u Back Panel Replacement: adım 5, 3 resimden 1. Gateway Lt4004u Back Panel Replacement: adım 5, 3 resimden 2. Gateway Lt4004u Back Panel Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Plastic Cards
    $2.99
    • Begin to slide the plastic card under the top edge of the keyboard. You will hear popping sounds and the keyboard will eventually be released.
    • Carefully pry the keyboard from the main frame, starting at the top section.
    • Look at the intel sticker in this step and the next to orient your computer with the pictures.
    FixBot'a Sor
    Yorum Ekle
  6. Gateway Lt4004u Back Panel Replacement: adım 6, 2 resimden 1. Gateway Lt4004u Back Panel Replacement: adım 6, 2 resimden 2.
    • Look at the intel sticker in this step and the previous step to orient your computer with the pictures.
    • Unplug the thin blue connection piece beneath the keyboard. It may pop off on its own while you are prying off the keyboard.
    • The popping noise will not hurt the computer.
    • Once the thin blue plastic has been detached, remove the keyboard from the rest of the laptop.
    FixBot'a Sor
    Yorum Ekle
  7. Gateway Lt4004u Back Panel Replacement, Back Panel: adım 7, 3 resimden 1. Gateway Lt4004u Back Panel Replacement, Back Panel: adım 7, 3 resimden 2. Gateway Lt4004u Back Panel Replacement, Back Panel: adım 7, 3 resimden 3.
    • Locate and unscrew the five screws indicated by the red circles in the picture using a Phillip's #0 screwdriver. All of the screws are 8.0 mm, excluding the top right screw which is shorter. It should be 5.0mm.
    • Each screw should have the word "DOOR" engraved beside or above it.
    FixBot'a Sor
    Yorum Ekle
  8. Gateway Lt4004u Back Panel Replacement: adım 8, 3 resimden 1. Gateway Lt4004u Back Panel Replacement: adım 8, 3 resimden 2. Gateway Lt4004u Back Panel Replacement: adım 8, 3 resimden 3.
    • Hold the computer in your hands and use the tip of your screwdriver or a spudger to push through the bottom right hand hole left by the removed screw. This hole is shown in the picture within a red box.
    • The tip of the screwdriver will push against the bottom casing of the laptop and pop it away from the rest of the frame.
    • There will be a loud cracking noise as the bottom of the computer detaches. You are not breaking it!
    FixBot'a Sor
    Yorum Ekle
  9. Gateway Lt4004u Back Panel Replacement: adım 9, 3 resimden 1. Gateway Lt4004u Back Panel Replacement: adım 9, 3 resimden 2. Gateway Lt4004u Back Panel Replacement: adım 9, 3 resimden 3.
    • Close the laptop and place it in front of you face-down with the hinge connecting the screen and keyboard away from you on the table. Pry the rest of the bottom casing away from the computer, exposing the inside.
    • Note that the laptop in this picture has both been placed upside down and rotated 180 degrees from the previous picture.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Carlisle Hiott
821 İtibar
7 adet Kılavuz yazıldı
Ekip
Clemson, Team 6-5, Benson Spring 2016 Clemson, Team 6-5, Benson Spring 2016 üyesi
CLEM-BENSON-S16S6G5
4 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 22
Her zaman: 868
