Ana içeriğe geç
Gateway M-2626u Battery Replacement
  1. Gateway M-2626u  Battery Replacement, Battery: adım 1, 1 resimden 1.
    • To prevent injury, make sure the laptop is not plugged in while removing the battery!
    • Make the switch in the upper right corner of the turned over laptop is switched to the "unlocked" position. (the unlocked padlock icon)
  2. Gateway M-2626u  Battery Replacement: adım 2, 3 resimden 1. Gateway M-2626u  Battery Replacement: adım 2, 3 resimden 2. Gateway M-2626u  Battery Replacement: adım 2, 3 resimden 3.
    • Push the switch to the right, toward the inside of the computer to dislodge the battery.
    • Finally, pull the battery outwards and away from the laptop as depicted in this image.
Sonuç
Tanya Jain
317 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G2, Peak Spring 2018 UMass Dartmouth, Team S3-G2, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S3G2
2 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 184
