Ana içeriğe geç
Gateway M-2626u CD Drive Replacement
Neye ihtiyacın var
  1. Gateway M-2626u CD Drive Replacement, Battery: adım 1, 1 resimden 1.
    • To prevent injury, make sure the laptop is not plugged in while removing the battery!
    • Make the switch in the upper right corner of the turned over laptop is switched to the "unlocked" position. (the unlocked padlock icon)
  2. Gateway M-2626u CD Drive Replacement: adım 2, 3 resimden 1. Gateway M-2626u CD Drive Replacement: adım 2, 3 resimden 2. Gateway M-2626u CD Drive Replacement: adım 2, 3 resimden 3.
    • Push the switch to the right, toward the inside of the computer to dislodge the battery.
    • Finally, pull the battery outwards and away from the laptop as depicted in this image.
  3. Gateway M-2626u CD Drive Replacement, CD Drive: adım 3, 2 resimden 1. Gateway M-2626u CD Drive Replacement, CD Drive: adım 3, 2 resimden 2.
    • Using the Phillips #1 screwdriver, remove the indicated 6mm screw holding the CD drive.
  4. Gateway M-2626u CD Drive Replacement: adım 4, 2 resimden 1. Gateway M-2626u CD Drive Replacement: adım 4, 2 resimden 2.
    • Using the screwdriver, push the release button for the CD drive.
  5. Gateway M-2626u CD Drive Replacement: adım 5, 2 resimden 1. Gateway M-2626u CD Drive Replacement: adım 5, 2 resimden 2.
    • Remove the CD drive from the device.
Sonuç
Femi
219 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 23
Son 30 gün: 51
Her zaman: 418
