Ana içeriğe geç
Gateway M-2626u CPU Replacement
Neye ihtiyacın var
  1. Gateway M-2626u CPU Replacement, Back Panel: adım 1, 2 resimden 1. Gateway M-2626u CPU Replacement, Back Panel: adım 1, 2 resimden 2.
    • Using the Phillips #1 screwdriver, remove the four 6mm screws on the back of the laptop.
  2. Gateway M-2626u CPU Replacement: adım 2, 2 resimden 1. Gateway M-2626u CPU Replacement: adım 2, 2 resimden 2.
    • Insert the plastic prying tool and pry the back panel off starting at an edge and moving your way around it.
  3. Gateway M-2626u CPU Replacement, CPU Fan: adım 3, 2 resimden 1. Gateway M-2626u CPU Replacement, CPU Fan: adım 3, 2 resimden 2.
    • Remove the header by pulling on it with two fingers.
  4. Gateway M-2626u CPU Replacement: adım 4, 1 resimden 1.
    • Remove the six 2.5mm screws using a Phillips #1 screwdriver.
  5. Gateway M-2626u CPU Replacement: adım 5, 1 resimden 1.
    • Remove the fan by moving it to the side and lifting it out of the computer.
  6. Gateway M-2626u CPU Replacement, CPU: adım 6, 1 resimden 1.
    • Once the fan is removed, locate the CPU.
    • Rotate the plastic knob using a flat head screw driver as depicted in this image
  7. Gateway M-2626u CPU Replacement: adım 7, 1 resimden 1.
    • Lift and remove the CPU from the mother board socket.
Sonuç
Armani Tayeh
432 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G2, Peak Spring 2018 UMass Dartmouth, Team S3-G2, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S3G2
2 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 9
Her zaman: 284
