Ana içeriğe geç
Gateway M-2626u Hard Drive Replacement
Neye ihtiyacın var
  1. Gateway M-2626u Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • To prevent injury, make sure the laptop is not plugged in while removing the battery!
    • Make the switch in the upper right corner of the turned over laptop is switched to the "unlocked" position. (the unlocked padlock icon)
  2. Gateway M-2626u Hard Drive Replacement: adım 2, 3 resimden 1. Gateway M-2626u Hard Drive Replacement: adım 2, 3 resimden 2. Gateway M-2626u Hard Drive Replacement: adım 2, 3 resimden 3.
    • Push the switch to the right, toward the inside of the computer to dislodge the battery.
    • Finally, pull the battery outwards and away from the laptop as depicted in this image.
  3. Gateway M-2626u Hard Drive Replacement, Hard Drive: adım 3, 2 resimden 1. Gateway M-2626u Hard Drive Replacement, Hard Drive: adım 3, 2 resimden 2.
    • Using the Phillips #1 screwdriver, remove the three 6mm screws holding the hard drive panel in place.
  4. Gateway M-2626u Hard Drive Replacement: adım 4, 1 resimden 1.
    • Using the plastic opening tool, pry open the plastic panel covering the hard drive.
  5. Gateway M-2626u Hard Drive Replacement: adım 5, 3 resimden 1. Gateway M-2626u Hard Drive Replacement: adım 5, 3 resimden 2. Gateway M-2626u Hard Drive Replacement: adım 5, 3 resimden 3.
    • Using your hands, carefully pull out the hard drive from its compartment.
Sonuç
Femi
219 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G7, Peak Fall 2018 UMass Dartmouth, Team S3-G7, Peak Fall 2018 üyesi
UMASSD-PEAK-F18S3G7
3 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 15
Her zaman: 270
